All fault codes can be checked out at
http://www.bluejag.co.uk but here are the results for some of yours. You can ignor P1111. Looks like a faulty plug or coil pack cylinder 2
Fault Code:- P1314
Indicates a Power-train fault The fault is generally due to a problem in the Ignition or Misfire area Fault Description: Misfire rate catalyst damage -bank 2 NOTE: This DTC will flag only when accompanied by an individual cylinder misfire DTC: P0300 - P0306
Action of ECM:- ECM Default:- Maximum engine speed reduced
After clearing the DTC, complete the Misfire monitor drive cycle
Check for a reoccurrence of fault DTC. Possible Fault:- Cylinder compression low Worn camshaft / broken valve spring(s) Fuel delivery pressure (low / high) Fuel injector(s) restricted / leaking Fuel injector(s) continuously open Fuel contamination Fuel injector circuit fault(s) (Injector DTCs also flagged) Spark plug failure / fouled / incorrect gap ECM to ignition coil primary circuit fault (Cylinder misfire detected DTC also flagged) Ignition coil failure
Fault Code:- P1316
Indicates a Power-train fault The fault is generally due to a problem in the Ignition or Misfire area Fault Description: Misfire excess emission NOTE: This DTC will flag only when accompanied by an individual cylinder misfire DTC: P0300 - P0306
Action of ECM:- none
Fault Code:-
P0302
Fault Description: Misfire detected ?€" cylinder 2
Possible Fault:- Refer to P0300 Possible Causes
haven't had time to return to B'ville (ironically, helping somebody else with their car) but did visit library and get copy of electrical;
