Tomtom GO 720 GPS Receiver Logo
karen morgan Posted on Aug 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Tomtom 720 will not turn on even after pressing reset button
And following the instructions to reset,have tried this now lots and still will not turn on...help. my tomtom is not even 12 months old and is not in constant use at all..i only had iton 3 weeks ago and it was fine.
Anonymous
Level 3:
President:
  • Master 1,111 Answers
  • Posted on Aug 18, 2009
Anonymous
Master
Level 3:
President:
Answers
1111
Questions
6
Helped
381056
Points
3221
Hook it to your usb cable to your for a few hours and then try and start it. first with the power button, it that fails try the hard reset..if neither those work, download tomtom home. follow the directions and tomtom home should be able to repair it unless you have internal problems, like a bad usb port on the gps. bill
2helpful
My tomtom 720 gps is back to factory setting. I need help resetting to English.
From the main menu screen, select "Change Preferences". Then look for (tap arrow at bottom) "Change Language" button. Tap the language (listed) and follow the instructions to confirm the language selection and choose a voice.
1helpful
My sat nav xl one is off with the green light on, I cannot turn it on and there appears to be no reset button
First, check and make sure your battery is fully charged. Then try to do a "Reset" .... by pressing and holding down the ON/OFF button for 5 seconds (or a lot more) until the device powers on again. Yes, at times, it may take a minute or more ! of holding that button down.
My tomtom 720 will not turn on
push the reset button for 15 second then push on/off button for 5 second, it will start now
6helpful
3answers
Tomtom go 4V00.710. Green light is on when charging but tomtom will not turn on.
i had the same problem; there is a simple reset solution, which is not described in either of the manuals which i have.
This involves removing the SD card, pressing a (tiny) reset button for 15 seconds, pressing the on/off switch for 5 seconds, then replacing the SD card. To locate the reset button, try the TOMTOM website/Support
My go 720 gps keeps freezing up
try resetting it, if that doesnt work, connect your unit to tomtom home. if you dont have tomtom home, follow the link at the bottom.
To reset your TomTom device, do the following:
  1. Check that the battery is charged properly.
    Charge your device for at least 2 hours before trying to turn it on again. Make sure the charging light on your device is on.
  2. Remove the SD card
    If your device uses an SD card, remove it.
  3. Reset your device.
    Use a straightened paper clip, or something similar, to push the reset button for 15 seconds. See the pictures below for where to find the reset button.
  4. Turn your device on.
    Press the On/off button for at least 5 seconds.
  5. Insert the SD card
    If your device uses an SD card, insert the SD card.
4helpful
Restore to factory setting
n rare cases, your TomTom device may not start correctly or may stop responding. If this happens, try resetting your device. The only information lost on your device is the clock’s time zone setting. Select your device from the list below to see how to reset it.
Select your device: TomTom GO 940/740/540 TomTom GO 930/730/630/530 TomTom GO 920/720/520 TomTom GO 910/710/510 TomTom GO, GO 300/500/700 TomTom XL IQ Routes TomTom XL (30-Series) TomTom ONE XL TomTom ONE IQ Routes TomTom ONE 30 Series TomTom ONE 3rd Edition TomTom ONE 2nd Edition TomTom ONE 1st Edition TomTom RIDER 1st Edition, RIDER 2nd Edition TomTom ECLIPSE II TomTom DAIHATSU, TomTom ECLIPSE, TomTom TOYOTA Help Not sure which device you have? ico_close.gif Type the first two characters of your device's serial number below to find out.
The rest button is on the top of the GPS
4helpful
2answers
I plug in my tomtom go 720 and I get an error.
Bless your cotton Socks crawdaddydoo !!! pressed reset button on GPS unit, Put it back in cradle, turn it on ... ta dah its working again..... Thank you VERY VERY MUCH...
Doesn' t turn on
1. Connect the TomTom to the USB for power (green light should be on).
2. Hit the reset button on the bottom of the device - you should feel it depress slightly.
3. Press firmly and hold the power button and count to 10.
5. Try this a couple of times if it doesn't work the first time.
Even if your battery is ****, the power connection has a pass-through, so you can still use the device as long as its connected to the charger.
10helpful
4answers
Top Tomtom GPS Experts
k24674
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
