I need to get pincode for a prepaid samsung att phone but i am using it under my att account and i want to lock my keypad but to do so i must have the previous pincode and i have no clue what that was?
If the phone is locked to a particular network you will need to get it 'unlocked'. Depending on how new your handset is most good phone repair shops will be able to unlock it for a small charge.
Unlike flip phones, cell phones like the Samsung Intensity are subject to accidental keypad-pressing and dialing when they are in your pocket, purse, or even a holster. To avoid unintentionally using up voice or data minutes, you can lock your phone and temporarily disable the keypad.
There are two ways to lock a Samsung Intensity - the standard keypad lock and the security lock.
- To use the standard lock:
You can lock your phone at any time from the main screen by holding down the "0" key for about two seconds. The keypad will immediately lock, and you won't be able to use any functions or make any calls (except for calling the local emergency number). To unlock the phone, press the right option button (in the upper right corner of the keypad, next to the End button) followed by the Menu or OK button.
You can also set up Auto Key Lock, which will automatically lock your keypad after the backlight turns off. The Auto Key Lock setting can be found in the menu under Settings & Tools > Phone Settings > Auto Key Lock.
- To use the security lock:
The security lock also prevents your keypad from being used, but it requires a code to be entered in order to unlock the phone. To enable the security lock, go into the main menu and select Settings & Tools > Phone Settings > Security > Lock Phone Now. (You'll need to know your phone's security code in order to access this setting -- by default it is typically the last four digits of your phone number.)
To unlock the phone, press the right option button and then enter your phone's security code, followed by the OK button.
You can set your phone to go into security lock mode as soon as you turn it on by enabling Phone Lock Setting under the Security menu. Every time you turn your phone on, you'll need to enter the security code in order to unlock it. However, once you unlock it, it will remain unlocked until you either manually lock it or turn it off and then back on.
A prepaid phone can be unlocked for use of any other international prepaid ( GSM ) connection only. Anyway, You can unlock a Samsung U360 using unlock code. You can get the unlock code for a Samsung U360 from www.Mobileunlocksolutions.com at affordable cost with easy unlocking instructions. All the best mate.
If you've unsuccessfully entered the PUK 10 times, the SIM Card is permanently locked. If not, then this solution is free from ATT, assuming you have ATT.
You can get your PUK code online by following these steps:
if you are using a sim card from a prepaid phone just bought, and then add it to another att branded phone, it will not work. if you use the sim card in the new prepaid phone, it will work. att locks the sims from working in other phones for 3 months from the factory. i did the same thing with a prepaid phone and a Q9, put the sim in the q9 and it said, no service. put the sim in the prepaid phone, it worked fine. my suggestion is to talk nice ot the att store employee, and they will give you a new sim.
let me know if your phone is doing something different.
Samsung i607 is usually locked to AT&T or Unlocked. Either way you should have no problem in putting any AT&T prepaid or other Sim card in it to use. There is nothing special that you need to do to do this. Just remove the battery and find the SIM slot with the picture showing you which way to insert the Sim card. Then put in the battery and turn the phone on.
sorry but the only way thatt it could possibly work is if you got blackberry unlocked for any gsm network but even on a prepaid service with the blackberry you lose the privilage of internet,picture message,and email.
If you have an AT&T account: FOLLOW THESE STEPS TO NETWORK UNLOCK SAMSUNG SGH-A737
GET THE UNLOCK CODE FROM ATT CUSTOMER SERVICE 18003310500
1. REMOVE SIMCARD AND TURN ON HANDSET 2. The display will read INSERT SIM CARD 3. TYPE #7465625*638*--------# .THE DASHES ARE YOUR 8 DIGIT UNLOCK CODE OBTAINED FROM ATT CUSTOMER SERVICE. 4. U WILL GET A MESSAGE SAYING NETWORK LOCK DEACTIVATED.
after the second asterisk, you'll see a dash ("-") on your screen instead of the number you type.
