Oil warning light goes off tends to be when going over 60mphcheck oil level it is fine. Garage siad it burning oil suggested fitting a new pump. Will this help? If not what can I do?
Thanks, been told it burning oil. Used about 2 litres in 6months.
Had new filter and oil change last week but made no difference. Warning light still going off even when car doing 30mph round town.
If it isn't oil pressure switch what else is it likely to be?Thanks, been told it burning oil. Used about 2 litres in 6months.
You can't post conmments that contain an email address.
The warning means you're low on oil and you need to top off the oil. Add about 1/4 quart of oil to the engine and check the dipstick. Add oil in 1/4 quart increments until the dipstick indicates the level correct. The dipstick on this car is hard to read, if you're uncertain about the level, just add oil in 1/4 quart increments until the warning goes off. If it goes off, then comes back after only a short time, then add 1/2 quart, and so on. These cars go through about a quart of oil every 5000 - 10000 miles normally (depending on various factors).
Have you checked your thermostat. Some cars do not have gauges for all componants of the car located on the dash board. A bad thermostat could drive the oil pressure gauge up, if there is not a coolant level gauge on the dash board.
Incorrect level. Check level at operating temps and while the engine is running. By sump and stainer you meant that you removed the oil pan off the car and cleaned the pickup tube of the oil pump? I'd suggest hooking up an oil pressure gauge so you'll know which part of the engine is starving oil and setting the warning.
The oil pump is relatively easy to change with the engine in situ if it is (commonly) at fault,
Get an oil pressure gauge with a pipe and brass fitting ready on, (borrow or buy cheap from boy racer shop), unscrew the sensor (or ask the garage to for a £5) and plug it directly into the sensor hole after you've been for a run.. When warm, mine sits about 40 at motorway speeds, ten at tickover.
After checking out alot of Honda/Acura forums I'm finding that many owners experience the same problem you are having. The best explanation I found was at 2carpros: http://www.2carpros.com/forum/94-acura-legend-burning-oil-vt7734.html From what I'm reading, only way to stop the oil loss is a new engine. If your car is running fine, I'd hesitate to change anything with the engine and stock up on oil.
If you low oil light is not illuminated it is ok to drive to the dealer. Putting 4 quarts in might have overfilled it leaving it to leak overboard on engine. You did not say that the smoke was coming from the tail pipe.
this would not be in effect of any oil leaking i would say your oil sensor has gone and would need to be checked out by a auto electrician. i hope this helps .
Bought a very reputable diy service manual for the vehicle, and that plus a bit of thought and nous gave me the cure: no intrinsic problem other than loose relay connections. Went round with the wiring diagrams as guide checking all electrical connections in tight and relays fuses etc all good. Switched on and no problem any more.
By the way, vehicle is 1992 VW Polo - not Fox (which in UK is a variant of the Polo)
