you will need to reset your ipod this will not delete songs.
1 Toggle the Hold switch on and off (slide it to HOLD and then back again).
2 Press and hold Menu and the Center button for at least 6 seconds, until the
Apple logo appears.
If iPod nano won’t turn on or respond
â Make sure the Hold switch isn’t set to HOLD.
â The iPod nano battery might need to be recharged. Connect iPod nano to your
computer or to an Apple USB Power Adapter and let the battery recharge. Look for
the lightning bolt icon on the iPod nano screen to verify that iPod nano is receiving
a charge.
To charge the battery, connect iPod nano to a USB 2.0 port on your computer.
Have you actually been holding down all buttons? If so you will want to reset the ipod. Just in case you are unsure as to how to reset the ipod I have posted a step by step below. Hope it helps you :)
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer.
Press and hold the center button while holding down the menu button. This will reboot your Ipod. Check your IPod cable to see if its shorted. If might have transferred a song and crash in the middle of the transfer.
hold down the middle button and the Menu button until the apple icon came up on my iPod. At once, the iPod icon returned to my desktop AND on my iTunes window. Works great now. Just like nothing happened.Good Luck!!!!!!!
- check the cable
- check the connections on the bottom of the ipod for bent pins, or dirt
- make sure ipod battery is fully charged
- if you have all your library backed up, reset ipod to factory. You will lost all settings etc. though.
- check usb ports are working properly with no conflicts or driver issues (control panel\system\hardware\device manager)
- uninstall usb ports on pc, let pc redetect them
