I need a diagram of the ignition control system for a 1992 Ford Explorer 4 wheel drive V-6 Vehicle abruptly stopped running and has no spark, changed ECM, crank positioning sensor, changed the coil, checked all fuses, checked spark plugs, checked to make sure fuel rail had pressure, all good.
Find yourself a electrical distribution diagram an see where the B+ voltage to the ignition comes from . An you need to be a little more specific ! Ignition system or ignition switch .
Free wiring diagrams here http://www.bbbind.com/free_tsb.html
Enter vehicle info. year , make , model an engine size . Under system click on electrical distribution ,then under subsystem click on power distribution . Click the search button then the blue link's one at a time .
Do you know what electronic throttle control is ?
It should be noted that the ETC system includes a wrench light on the instrument cluster that illuminates when a fault is detected. Faults are also accompanied by DTCS and the "Check Engine Soon" light.
Your best bet mite be to take it to a qualified repair shop.
Find a dirt or gravel road or driveway and accelerate hard from a complete stop. If it is in 4wd, the vehicle should take off with little or no wheel spin. If it is in 2wd, the back wheels will spin easily. Be careful and maintain full control of your vehicle while doing this.
from front to back
1-2-3 on passenger's side
4-5-6 on driver's side
the coil
1-2-3 in the rear counting from passenger's side
5-6-4 in the front counting from passenger's side
Suggest you have a professional do this one. If everything is not put together correctly, you can lose control of the vehicle and hurt yourself or others.
There is no cap and rotor, as the vehicles igntion system is DIS (digital ignition system). The recommended tune-up on these motors require sparkplug and coil replacement. The coil type in this vehicle is COPs (coil over plugs). Usually moist and oxidation develope on the sparkplug chamber walls from faulty or worn coil boots. This causes the coil to short, they must be replaced at 75,000 miles at the same time the sparkplugs are replaced. Typical symtoms are: Vehicle stalls (restarts and runs normal), intermitted jerks/sputter while driving, misfires, rough idle, severe power loss. Hopefully this helps
1991-1994 2.9L and 3.0L Engines Firing Order 1-4-2-5-3-6
1995 And Later 3.0L V-6 With DIS Ignition System Firing Order 1-4-2-5-3-6
4.0L Engines Firing Order: 1-4-2-5-3-6 DIS Ignition System
no rotor, has coil pack
