How to diagnose the diference between a bad water pump or just a bad t-stat?
Not that big a job, to pull the t-stat and test it in hot water in the house.
If you have a candy thermometer and a large pot, suspend the stat in the water via string, heat the water and observe if the stat opens up.
If yes, the at what temp, most are between 170-190 degrees?
If not then you have at least one suspect.
You can also button up the Ford and start it up, does it still over heat without the stat?
Even with the engine cold the pump should still circulate water.
Either way the fastest method is to turn a few wrenches to get a suspect stat out to test.
If you have a cooling issue when was the last time you changed fuild and/or did a superflush of the cooling system?
