You can contact a electrical person, let he come to check your diesel generator.
If you need to have a new diesel generator, maybe you can contact Starlight factory, they have focused on diesel generators for more than 40 years, brand Cummins, Volvo, perkins, Yuchai, Shangchai etc.. They are OEM factory of these brands. The email address: [email protected] or website: www.dieselgeneratortech.com
SOURCE: generator starts but gives no 220 volt electric
This is a frequency issue 50 hertz for Europe, 60 hertz in US. It's speed related. Faster RPM for 60 Hz
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
SOURCE: Kipor Diesel Genrator gives lotta smoke & consuming too much fuel
1- make sure the air filtr is clean
to make sure the problem is not from the air filter run witout air filter
2- there must be a ajustabe screww which controls the amount of fuel out put from the injector turn that screw and see the result .
3- make sure the engin is not burning oil . by checking the level of oil every 6 runing hours you can figuer this out
4- some smoke is normal with dissle engines
SOURCE: Looking for Instruction manual for
You have a Lutian generator made in Zhejiang, China. Here it is with some information.
http://lutian.en.made-in-china.com/product/dqwQkPYcEAVv/China-Diesel-Generator-5GF-LDE-.html
Here is a link with more specs and they list it as Yangke.
Fuel tank capacity (L) 16
Lube capacity (L) 1.65
Fuel type Diesel 0# (summer), diesel -10# (winter)
Lube brand SAE10W30 (above CC grade)
http://www.trademetro.net/GF-LDE-GF-153435.html
Here is the telephone number of the supplier in China
86-576-82620992
82642888 82645288
Or you can go to this site and contact them. Do not trust this site with any personal information or credit card numbers.
http://lutian.en.hisupplier.com/product-188200-Diesel-Engine-Generator.html
I was unable to find an owner's manual anywhere but hopefully by contacting one of these sites you can acquire one.
SOURCE: My diesel kipor 5kva generator wont shut by key ,
Caution
the manufacture is recommending a cool down period of about 3 minutes to prevent overheating of the combustion chamber. the following is from the manufacture on shut down procedure.
3.2.8Check Stopping of Generating Set
(1)Disconnect the load from the generating set.
(2)Turn off the air switch of the generating set.
(3)Set the speed lever at RUN position, run the generating set without load for about 3 minutes. Do not stop the engine suddenly, otherwise the temperature will increase abnormally, the nozzle will blocked and the generating set will be damaged.
Press down the stop lever. Concerning the electric starter, turn the key to OFF. Turn the fuel **** lever to S position.
Pull out the recoil starter handle until you feel resistance (at this position, both intake/exhaust valve are closed.) and leave the handle in this position. This prevents the engine from rust.
If the engine keep on running even after the speed lever is placed at the STOP position, either turn the fuel **** to the CLOSE position or loosen the nut of high pressure fuel pipe on the pump side to stop the engine.
Do not stop the engine with the decompression lever.
Do not stop the generating set with load. Stop it after the load removed.
the following link provides the complete maintenance manual for the diesel generator
http://www.rcremers.nl/webshop/handleidingen?download=20:handleiding-aggregaat
It might be caused by low or high oil pressure.
When generating set is working, what reasons cause oil pressure gauge and what solution is there?
The principle of engine lubrication system produced by engine oil pump shows that the pressure of lubricating oil is mainly due to the resistance of oil flow in the pressure section of the system, and its pressure is related to the flow resistance of oil in the system. The oil pressure is high when the flow resistance of oil in the system is high, and the oil pressure is low when the oil flow resistance in the system.
https://www.dieselgeneratortech.com/generator-sets/Reasons-and-Solutions-for-Oil-Pressure-Problem-of-Generator-Set.html
