On the brake light switch check the harness sometimes it gets to hot and terminals won't make contact they open up. Try wiggling the brake switch harness while pressing brake with other hand truck running or key on engine off and listen for solenoid clicking everytime you press the brakes.
I went off your primary post of brake lights staying on replace switch now won't go in to gear (stuck in parking)
Are your brake lights working?
If not, replace the fuse. Still not working? Replace the brake light switch. (Your brake light switch also releases the lock for the gear shift).
If your brake lights are working, are you hearing a soft "click" at the gear shift when you depress the brake? If not, check the lock solenoid at the gear shift lever.
There is also a slight possibility that your park pin is jammed. If you're parked on a hill, it's likely. Have someone push the car back and forth as you try to take it out of park... JUST DON'T RUN THEM OVER. :)
Sounds like just the brake-shift interlock getting stuck. I would try using the override to get the shifter working again, then use the parking brake to keep it from getting jammed in the future.
The parking brake will reduce the pressure on the gearbox, especially when parked on an incline. If the interlock continues to jam, you probably do need to have the shifter replaced.
