Orange light at the ethernet cable to the dvr and wont pick up ip address
SOURCE: Dlink Router not assigning IP to NAS
DI-624 (Update to FW 2.70+)
See: http://www.infrant.com/wiki/index.php/Hardware_Compatibility_List_-_Network_Switches/Routers#D-Link
SOURCE: Actiontec MI424 and Direct TV DVR
Your DVR need to be set at 71.182.140.*** *** meaning an available address. Then they will connect.
What is make and model number of the DVR?
SOURCE: cannot pick up Ip address
try this it has worked for me many times
http://www.howtofixanything.co.uk/howto-269.html
SOURCE: I'm looking to hookup the DVR with the PC via A cross-over cable
I have 2 DX2000's, In order for you to communicate with your pc, you need a Crossover cable, if you have a laptop or computers, connect the crossover cable to that, set your ip address on your computer to 192.168.2.108, (Note: since you never configured it, this would be the default setting). If you have the manual this is in there.,
Another method, if you don't have a crossover cable is to set the ip on your computer to 192.168.2.110 Subnet, 255.255.255.0. its a little more funky, the crossover would be easier, once you get in, then go to the configuration page and setup up the IPaddess for the DX2000, the Gateway to your Router and the subnet mask, once you do this, then you're able to get to it on your network, by typing in http://xxx.xxx.xxx.xxx:8004 .
SOURCE: cant see snc rz30n, appear ip ip setup window, won't load page
Enable network and then give ip in the address bar of browser the home page will be browse.
im not a techie so need help
