SOURCE: quand je démarre on me demande un mot de passe microsoft
Translated from French (after making spelling & grammar corrections):
> When I started asking me for a password from Microsoft.
> Since I do not know, I close the window. It worked.
> Thus since the purchase (approximately one month)
> but now I can no longer write files that I open.
> What to do? Thank you in advance.
Return to the store that sold the computer to you, 30 days ago,
and ask them for the password.
The software was a "trial" version that could be used for 30 days.
Your 30 days have ended, and so you must either purchase the software, or stop using the software.
SOURCE: aeg 72620 affice code cd et ne démarre pas
error "cd" means door lock defective although I have found that the main electronic board is uaually the fault and not economic to repair.
SOURCE: Battery Packs for Powerware 9355 UPS
If you battery packs are all at 130volts DC, then all of the packs will have become dead, and the batteries are not recoverable. Your battery DC bus voltage on a Powerware 9355 20 to 40kVA rated UPS is nominal 432 volts DC - 36 batteries in series in each string at 12 volts DC per battery. If batteries go below 10.5 volts DC each, or 378 volts DC bus voltage, no amount of charging will recover these batteries. You should not be recycling the DC battery breaker, unless you felt the battery breaker was faulty. The UPS would have given you an alarm message of either battery breaker Off, Charger Failure, or Low DC Bus Voltage long before the these batteries failed.
The battery test will not proceed if the batteries are dead.
Well, here's the manual and I can find no numerical alarm codes in this manual.
http://static.ziftsolutions.com/files/8afe1787416e8d3d014175ca30004cbb.pdf
