Please assit with White Rogers Thermostat Manual 1FS97-374. Why Check STAT comes? Thank you, Kumar
The display will indicate CHECK STAT if one of the following occurs.
• One of the buttons is stuck down or in. Check buttons, make sure nothing is pushing them in.
• The thermostat sensor is not functioning. If using a remote sensor, check connections, wiring and power.
• The humidity sensor is not functioning.
After checking the above, press PROGRAM RUN to reset the display. If this does not clear the display, disconnect power and remove the batteries for five minutes.If these checks fail to solve the problem, the thermostat should be replaced.
