Do have an idiots guide as to how to wire up the SR-4200 to a TV
I will interperate this as:
"So you want to play sound through your Marantz SR-4200?"
You need to clarify what sort of system setup you have, however i will put down a few ways to wire this up to your TV.
If you have a Set-top-box that gets the TV Channels, that is where the sound comes from. If you have a TV that plugs straight into the wall, you will have to get the sound from the TV. Grab a RCA Stereo cable - (White and Red heads, if you don't know what they look like, Google it).
If you are unclear about this, i have tried to make a diagram down the bottom to explain how this is to work. What you will do is Take the sound from the Set-Top-Box or TV and reroute it into your fantastic Marantz SR-4200.
1. Plug Red Plug into the the Red Slot, and White into the White on the back of your set-top-box or TV Out (if you get it around the wrong way, the speakers will be reversed.)
2. Plug the other end of the cable into the back of your Marantz SR-4200 in the TAPE input or VHS input as they are analog signal inputs. Turn on Marantz SR-4200 and turn it onto Tape or Vhs (depending on where you plugged it in).
[Set-Top-Box or TV out] >-------> into >------> [Marantz SR-4200]
If you still don't get it, then try searching You-Tube for a guide "Plug Tv into Stereo". I myself couldn't turn up anything useful
