Televison & Video Logo
m
miri david Posted on May 13, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi, when i watch netfliks, my tv screen turn blunk, my internet is good my tv is good so the problem is with the roku ,since i watch nnetflix tru roku box
Technical Bulls
Level 2:
Novelist:
  • Expert 192 Answers
  • Posted on May 18, 2018
Technical Bulls
Expert
Level 2:
Novelist:
Answers
192
Questions
21
Helped
29801
Points
490
Hello Dear
Don't suffer through annoying pauses or blurry, low resolution. Here's how to get better streaming from your smart TV, streaming box or game console. Check out here....
For any Help or support visit here: www Roku Com Support
5 Related Answers
A
Anonymous
  • Posted on Apr 20, 2008
SOURCE: rca tru flat tv/ dvd model#(20f510td)
I'm having problems w/my dvd player - Its' not reading the DVD. How do I resolve the problem?
Thank you,
Janice
Anonymous
  • 85 Answers
  • Posted on Jan 07, 2011
SOURCE: I have a RCA model
First of all, make sure all components are powered up and plugged in. Next, check that your tv is set to the correct input by pressing tv/video or input button on either the front of your tv or at your remote. Scroll through the inputs by continuously pressing the input button until the see the roku video displayed on your tv.
Good Luck
Steve
  • 3290 Answers
  • Posted on Jul 31, 2012
SOURCE: Why does our TV go through the channell setup everytime we turn it on?
Hi Mary -
The first thing you should do is consult the set up procedures on Page 8 / Section 4 of the manual. This will assure that you have completed and exited this important section properly.
If the TV should lose power (power outage, blown fuse or circuit breaker, cord removed from the outlet, etc.) the TV will likely need to have the setup performed when powered again for the first time. Likewise, a TV that is plugged into an outlet controlled by a switch, will lose power when the switch position is changed. Since switched and un-switched wall outlets look the same, you will need to unplug the TV and plug in a table lamp or similar and operate switches to see if it goes out. You will need to try both the upper and lower outlets as they can be operated independently of each other. If you find that the outlet is switched, you will either have to stop using the switch or find another un-switched outlet to power the TV.
I didn't see it mentioned in the manual, but some TVs have a dedicated power and a dedicated on / off button. If the power button is set to off, the TV will shut off and the remote will not be able to turn the TV back on until the power button is turned back on. The on / off button on the TV allows the TV to be turned on and off with the remote - or the on / off button on the TV. Again, this will only work if the dedicated power button is on. If the power button is set to off, it may be causing the TV to lose the set up information - requiring that it be done again. Make sure that you are using the remote to turn the TV on and off - or the correct button on the TV if you do not have a remote.
If all fails, you might want to contact Sanyo directly. According to the manual, they can be reached at 800-877-5032. I hope this helps & good luck!
gopakumarg43
  • 76851 Answers
  • Posted on Feb 26, 2013
SOURCE: how do i reset my roku player
Watch this video.
Pcm2048
  • 754 Answers
  • Posted on Feb 25, 2016
SOURCE: Help getting a roku box given to me under my own account
You need to access the Netflix app. From the home screen it should show the Netflix app. Refer to the user manual if you have trouble with this, or if you do not have one, download the manual for your specific media player from the Roku site. If the media player is not responding you may need to do a factory reset. The manual will also cover this. Once you access Netflix it will prompt you to sign up a new account You will need to provide your credit card details.
1helpful
2answers
How do I get my Roku to turn on?
Hello Dear
Roku streaming players are low-power devices that are designed to remain on and always connected to the internet. There is no "power button" to press on or off. This easy-to-use design prevents confusion by enabling instant access to your player any time you turn on your TV or switch from another source (e.g., cable box, Blu-ray player, gaming console).It also allows your Roku player to download new OS software and channel updates automatically without interrupting your use of the player. Your streaming player only uses your internet connection when streaming, or during the occasional automatic software update. When not in use, your Roku streaming player does not use any material bandwidth of your internet connection.
·USB-powered Roku streaming players
The Roku Streaming Stick+, and Roku Express can be powered through the USB port on your television. This means it will automatically power-off when you turn off the television, but it also means that it will have to boot-up every time you turn on the television.
Note: The USB port on some TV's may be unable to power a Roku streaming player.
·Options for powering off Roku streaming players
Although Roku streaming players use very little power when not in use, you may still want the ability to power-off manually. To do this without having to remove the power cable, consider connecting to a power strip with a power button, or a smart strip that automatically turns off power when not in use.
Note: Your Roku player will have to boot-up every time you turn on the power strip.
For any help visit us: www Roku Com Link
1helpful
3answers
Pros And Cons Of Roku
Roku is one of the best streaming devices to stream the videos, movies and TV shows.
Pros of Roku
The Roku offers user interface and Roku app in cheaper packages.
Roku does not require the separate box or HDMI cables to connect the TV from the stick plugs.
It has screen mirroring features that display the screens of the mobile device on you Roku tv.
It has the search function to search the lists of channels from the channel stores.
It provides headphone jack for private listening.
Cons of Roku
For the Network connection, Wifi is the only option
You need HDMI cable for Roku stick because it lacks analog and digital audio outputs.
If you need further more information about the roku products contact the roku customer service team @ +1-844-965-4357 and you may visit https://www.rokuactivationcode.com/
1helpful
How do I download app for tubi tv on Samsung smart led 40inch t
In case you don't find the app anywhere, you may install the Tubi TV apk file directly after downloading it from a trusted source (I have provided a complete guide to the whole process for you below) and enjoy the services seamlessly. Hope this helps you out Tubi TV Apk Download Download Tubi TV App for Android and Windows
1helpful
Reset to factory reset. Roku logo floating around screen. remote not usable.
Hi Elaine!
First you have the TV's own remote to get back to regular TV programming by pushing the INPUT Button, Then Call Roku or go to this link I am providing you for help.
Good Luck,
JP
Featured Question
Roku has been working for months tv screen turned black today in middle of program now nothing. Roku is working because power indicator lights up but nothing on screen.
Check the video output cable (HDMI or composite/RCA, etc.) from the Roku to the TV, to make sure it's still connected. Verify that you're watching the input on the TV that the Roku is connected to. If that doesn't work, contact Roku support. I hope your unit didn't just die.
57helpful
2answers
Roku Customer Service Call 1-8O5-225-669O We are 24 Hour Available Call for Setup-Install-Fix Error.
Hi! I am roku product representative, You need to put the activation code from your roku to your roku account (if you have one) and just in case you don't have any roku account yet, you may create one or you may call a roku product representative 1-888-600-7658. thanks!
2helpful
I have a RCA model 24V511T can I hook up a roku receiver to view Netfliks etc from the internet. I have hooked up the red white yellow connectors to the input ports on the tv set and nothing happens?
Good Luck
Top Roku Televison & Video Experts
vince
Paul Carew
Are you a Roku Televison and Video Expert? Answer questions, earn points and help others
