SOURCE: CLUTCH QUADRANT 1998 Escort 55 van
easiest way i have found is to fit a cable off of and mk3 cortina which has the adjuster on the gearbox end,anyway the pedal shaft can be pushed over two plastic spacers keyway located either side of pedal ,evan an old hand like grandad here has a job as its so fiddly.not really a weekend mechanic one this one
SOURCE: wiper arm slips on shaft after tighting on 1996 sentra
you may have a bad set of splines either on the wiper transmission arm that the wiper arm attaches to or the splines in the wiper arm were it makes contact with the attaching point that you tighten.look closely as if these splines are bad it won`t matter how tight it is it will slip.you may have to get a new wiper arm(or used)or replace the wiper transmission depending what you find.assuming of course you mean the wiper will not move at the speed it should be compared to the other arm
SOURCE: need to remove axles on 2005 Silverado with limited slip rear end
they come out the same way you just need to fight with the clips a little harder
REMOVAL & INSTALLATION
See Figure 1
