@ Your E-Service AlertSite E-Servive Starter Kit (APAS-21B-WPP-0000) for Mac, PC Logo
Anonymous Posted on Aug 01, 2009
Email every time i send an email an attachment is automatically added.it's the same file all the time. how do i stop this? i have sent an email (outlook express) to microsoft about this and it was returned because of the attachment.thanx brian ([email protected])
  • Anonymous Aug 01, 2009
    regarding email attachments. i have avg and your solution did not solve the problem.Brian ([email protected])
Pavan Ponangi
Level 3:
  • Master 390 Answers
  • Posted on Aug 01, 2009
Pavan Ponangi
Master
Level 3:
Answers
390
Questions
Helped
115549
Points
1372
Hi Brian
this is because of a virus attack on your system
update the virus definition files of your antivirus program and run a deep scan of your sys else if you still in doubt then suggest that you
download one of the better free antivirus (like avira or AVG) uninstall the existing Antivirus software and install the new one update the Virus definitions of it and run a complete scan of the drives
once the virus is removed you will not face the problem any more
cheers
Testimonial: "no more roblem"
Outlook is sending multiple emails
Check your outbox and make sure the email you tried to send is no longer there because outlook tends to try and try sending a previously unsent email message.
Make sure the outbox is cleaned up.
In sending email with attachments, make sure the attachment is not too big that it exceeds 5mb to avoid these type of incidents, as a work around for multiple attachments you can try sending them in a different email message.
2answers
I have made an powerpoint presentation.I want to send it as an email.but when I click the send option.it doesnt get sent.what can be the possible problems? I go to microsoft power point.Select the file for...
Because you must use another program to send it - like Outlook.
Just do it the correct way: save the ppt file on your pc, close PowerPoint, open your mail program (Outlook or whatever) , compose a new mail , attach the ppt file to it and send the message to its destination.
2answers
Are there instructions available, for someone not that PC literate, to send an e-mail with a Winfax Pro document as an attachment?
If you know how to send an email, the rest is easy.. Firstly, save your winfax document into your "my documents" folder and make sure you remember the file name. Setup your email as you want it then click on the "add attachment" button at the top of the screen (this depends on which email system you are using but most attachments can be added from the new email screen). In hotmail and windows live, use the attach button and select file. In outlook and outlook express, use the attach button on the top toolbar. Click on file and a dialog box will open asking for the file you wish to attach. Use the box to navigate to your my documents folder and then select the winfax file you saved earlier. If the file is not showing, click on the file type box and select all files. once you have found your winfax file, select it and click on "ok" or "attach". Wait for the system to upload your file and then click on "send".. You're done !!!
swoop611....
1helpful
2answers
Need to delete email w/2 large of attachment after clicking send
1. Go the File menu, then choose Work Offline in order to stop Outlook from trying to send all mails:
2. Switch to the Outbox.
3. You now have two options:
a. Move the message: you can drag-and-drop or use the Edit: Move to Folder menu item to move the e-mail to your drafts folder. This will allow you to re-open the offending e-mail and slim it down by removing the large attachments before attempting to resend it.
b. Delete the message: this will immediately remove the message from the Outbox and put it in Deleted Items.
4.
If you receive an error at this point that says the message is being transmitted, close Outlook, wait for Outlook to exit (you may need to use Task Manager and wait for the Outlook.exe process to exit), and then start Outlook again and repeat steps 2-3. In some cases, the item may not be released until Outlook has restarted.
5. Go to the File menu, deselect Work Offline to start sending and receiving mail again.
1helpful
Outlook 2007 - Emails sticking in outbox.
try turning off the windows firewall or adding an exception for outlook, you can do this from control panel
1helpful
How to scan to email
dear customer,
these are some of the ways to do it.. hope its useful..
VistaScan - Scan to Email
VistaScan's direct email link requires either a MAPI (Microsoft Exchange compatible system) or VIM (Lotus cc:Mail system) messaging program - these are commonly used on corporate networks and aren't installed on normal consumer PCs - home and small business users can scan-to-email via PageManager or by attaching images as described below.
VistaScan 3.1 scan-to-email preferences for the commercial MAPI and VIM messaging systems - to reduce the size of file attachments the JPEG file format is recommended.
MAPI programs include Microsoft Outlook 97 and 98 (which can also be used with normal Internet mail accounts) and the latest Netscape Messenger client.
Outlook 98 is a commercial software package (not included with Windows), with support for Internet mail systems, Exchange Server or Lotus cc:Mail messaging servers. outlook98.gif
VistaScan 3.1 application used with Microsoft Outlook 98 - scan-to-email is selected as the destination for the image When VistaScan is used with either a MAPI (Exchange) or VIM (ccMail) mail system it will detect the presence of the software via the Windows registry and automatically launch the client and a new message window, with the single file attached - the message must then be written and sent before the scanner driver can be used again.
Sending images to Email Clients using Presto PageManager 4.0
Presto PageManager is a useful way to capture and archive scans before sending them to another program (eg image editor, word processor) or to print. A few email programs can be linked with PageManager, allowing an image to be "dropped" on a Application Button to automatically open a new message with the scan attached. Microsoft Outlook 98, Netscape Messenger (aka Netscape Mail), Lotus cc:Mail and Eudora Pro 3.0 can all be added as email applications - Outlook Express, Compuserve and AOL cannot be directly linked (these are limitations of the mail programs, not of PageManager!).
pmoutlookbutts.gif comm46butt.gif OutLook Express cannot link with PageManager - a new email won't be opened when selected. PageManager adds an Outlook Express button automatically. Outlook 98 will correctly open a new email and attach the scan(s). PageManager won't setup Outlook 98 automatically, it needs to be Registered as a new application. Netscape Mail will correctly open a new mail with attached scans when selected. The Application Button is setup automatically by PageManager.
Preparing Files for Email Clients
As many Internet email programs do not support Exchange or cc:Mail, the two commercial mail systems integrated with UMAX software, you may have to prepare your scans: the images to be sent need to be saved on your hard disk in a suitable file format, ready to be "attached" to an email.
In general it is better to send as small a file as possible by email, as the image has to be transferred to the Internet over a relatively slow modem link - most users prefer a compressed file format such as JPEG (.jpg). This compresses your scan to a fraction of the original size, although it does slightly reduce the quality of the images.
There are three ways you can save your scans to disk:
1. If you use the VistaScan program (Start, Programs, VistaScan 3.x, VistaScan) you have several choices in the "Scan To" box (Advanced mode).
Click on the Floppy Disk icon - this will then use the settings in the VistaScan preferences:
For emailing scans we recommend the JPEG format - check where the scans will be saved (which directory). File names are created automatically - scan1.jpg, scan2.jpg etc.
2. If you normally scan your images in to PageManager you can export them to your hard disk - right-click on the thumbnail view and choose 'Save As...':
Choose a file location and select the "Save as type" file format.
3. If you are aquiring the VistaScan driver via any other application (eg Adobe PhotoDeluxe) then you should have options to save the images and to change their formats - please refer to the instructions for each application for for further advice.
Attaching images to an Email
All email client programs will allow you to combine file atachments and your text in to a single message for sending - although there are small differences in the way attachments are encoded you normally only need to customise options if sending to someone with an Apple Mac, which supports slightly different graphics file formats. Below are instructions for attaching files in some of the more common email programs:
America OnLine (AOL) (3.0I)
In the Email menu choose Compose Email (Ctrl+E):
At any time while you write and address your email you can click on the Attach icon on the left of the window - this then lets you select the files to be sent.
Compuserve (CIS) (4.0)
In the Compuserve program choose "Create New Mail" from the Mail menu:
During writing and addressing your mail message you can click on the button "Attach File:" - this lets you browse your computer to select the scans to be sent. To make finding the files easier, change the "Files of type" setting to "Graphics Files". Once the files are selected Compuserve shows a second window of encoding options - the default (Binary) will be suitable for almost all emails.
Microsoft Outlook Express
Outlook Express is one of the most common Internet mail clients, and is included with many Windows 98 systems and on ISP disks - this basic mail program also lets you attach files to your emails. Click on the Compose Message button:
While writing your email message you can click on the paper clip icon (shown above) or choose "File Attachment..." from the Insert menu.
Netscape Mail / Netscape Messenger (Communicator 4.6)
The most recent version of Netscape Mail can be linked to PageManager or the VistaScan driver, however many users want to attach scans in the normal way - click the New Msg button to open a Composition window:
While writing your email message click on the Attach button and choose File... - locate and select your scans.
2helpful
4answers
Email stuck in outbox
Here's the fix if when you send an email attachment from another application it gets stuck in the Outlook Outbox...
[HKEY_CURRENT_USER\Software\Microsoft\Office\Common\MailSettings]
"StrictAccountOrder"=dword:00000001
Tooks us a long time to come up with it but great to have! It's fixed in Outlook 2007.
Bill
www.IVDesk.com
Complete hosted IT solution where we run all your applications and provide 24x7 support!
Work from any Internet connection anywhere.
2helpful
Outlook 2007 emails stuck in the outbox
I've had the same problem more that once. Today it sent the same message 21 times before I finally was notified and deleted it out of the outbox.
Top @ Your E-Service Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a @ Your E-Service Computer and Internet Expert? Answer questions, earn points and help others
