SOURCE: noise under hood like rattling sound
Try checking the heat shields on the exhaust pipe up front under the car. Alot of times they will loosen up, and begin to rattle. You can ither remove them, or try to clamp them.
Hope this helps!
SOURCE: a rattling noise from the engine bay
Check the heat shields on the exhaust system. They get loose from the extreme heat fluctuations work loose and rattle. Especially the one between the engine and firewall where the 02 sensor screws in. It probably rattles less after warm up because heat causes expansion which makes it tighter. Hope this helps.
SOURCE: Rattling noise - Renauly Megane
are you loseing oil
could be very low on oil
or bottom end going? be may its the sheild just come lose
SOURCE: engine or transmission knock / rattle upon
I had the same problem on my 2006 Lucerne and it was the engine mount located on the front of the vehicle behind the radiator.
