Heating & Cooling Logo
Jan Posted on Jan 18, 2018
My aircon nevo make give me a error E1 what is the problem
2 Related Answers
airconditioning
  • 40 Answers
  • Posted on Jul 05, 2014
SOURCE: pls help me to fix my aircon there is error E1
E1 Code validation check fail / shut down the unit and restart.
see more Air Conditioning Fault Codes
akanetuk
Akaninyene Etuk
  • 6 Answers
  • Posted on Jan 31, 2015
SOURCE: WHY IS MY AIRCON DISPLAY E1 ?
THIS MEANS THAT THE ROOM THERMISTOR ( A DEVICE CONNECTED TO THE THERMOSTAT THAT DETECTS THE ROOM TEMPERATURE IS SHORTENED OR DEFECTIVE AND YOU NEED TO HAVE YOUR AIR CONDITION SERVICED
What does error code En mean on everest window type aircon?
Generic Procedures for Clearing an E1 Error
  1. Turn off the air conditioner and unplug it.
  2. Hold down the power button, and keep it depressed while you or someone else plugs it back in. ...
  3. Unplug the air conditioner again and plug it back in.
https://www.hunker.com/13407286/how-to-fix-an-air-conditioner-when-it-gives-you-an-e1-code
Teach me how to fix aircon says e1?
Hello, Mari-vick -
Without knowing the model number of your Aircon (an air conditioner, I believe), I can only provide you with generic instructions.
I hope you have the owner's manual and have checked there regarding the E1 error code.
If you do not have the manual, then . . .
Reasons for E1 error code, air conditioner:
1. Clean or replace the air filter. Note: Unplug the unit first. After cleaning or air filter replacement, plug the unit back in to the electrical outlet.
2. If the E1 error code still displays, it could mean one of the following problems:
- loose internal connections
- indoor and outdoor parts communications problem
- faulty control panel
Note: You may need an Aircon authorized repair technician for any such repairs.
Read more about the E1 error code on air conditioners and what may be malfunctioning here:
Best wishes.
1helpful
How my aircon display E1?
High pressure or temperature cutout. Have the unit checked for a leak or a refrigerant flow problem.
2helpful
Pls help me to fix my aircon there is error E1
Goes on when it wants to and it displays E1
can give the model of that aircon
Split type
E1 Indoor and outdoor communication abnormal
possible damage main PCB at outdoor units due to power supply problem.
Top Heating & Cooling Experts
Paul Carew
john h
