I have the above clock which I bought many years ago in kit form. I have completely built the wooden case but I have lost the instruction manual on how to fit the clock mechanism, can you help me with any diagrammed.. Regards Mr. Bernard Francis
I'm not a clock maker nor repairman.. wait don't they have there own name? "Watch Maker" right? (Siler - from Heros)'
Anyway,I've doodled with a couple and came across a tip. Make a stand to hold and test the mechanism while you work on the case. By making a comparable stand it will give you some idea of how the holder should be shaped. You could probably start with mounting a simple box with no bottom to the wall and use a few pieces of wood to let the clock works sit and allow the weights to work and to swing the pendulum. Would be a good idea to get the timing done at this time as it does take a while to adjust, wait, and adjust again. It took me 3 to 6 months to get ours just right.
Good luck, Aloha! ukeboy57
SOURCE: Setting Clock for JVC-KD-G420
Here is the link for the manual http://books.jvcservice.com/download/289413083/38360.pdf page 7 Hope this helps :)
SOURCE: Instruction Manual for Telemergency 700 Unit
Hi - Telemergency's website does not have the manuals but has the contact details, scroll to the bottom of the page by clicking the link below:
Telemergency
Call or email to ask for a replacement manual.
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
SOURCE: Lost instructions for Lexon world time clock model Planete
to set the alarm, press and release the "alarm" button; then press and hold the "set" button until the hour begins to blink. press "adv" until
the hour AM or PM is correct;now press and release "mode" so that the minutes begin to blink. Set the minutes using "adv"; now press and release "set". Finally,
press and release "adv" once to bring up (or remove) the alarm icon. Then press"alarm" once to return to the main display.
To set main display, press and hold "set" until the hour begins to
blink; press "adv" repeatedly until hour AM or PM is correct. Now
press "mode" so that the minutes blink, and use "adv" to get the
minutes right; then press "mode" so that the next item begins to
blink; use "adv" to advance until it is correct, then press "mode"
so that the next item blinks, and so forth until you're all done.
Finally, press and release "set".
Testimonial: "It took a while to get a response, but the answer was correct and very helpful, thanks."
SOURCE: Manual for Emerson smartset alarm clock
As you haven't mentioned the model no. so I am giving you a link from where you can download the manual for your appropriate model.
Good luck....and have a nice day.
Rating the solution is highly appreciated.
SOURCE: Lost my owner's manual for my TIMEX T307S clock radio.
You can download the user manual from this link
http://www.timexaudio.com/pdf/T307_IB56281_07.pdf
