Cell Phones Logo
N
Noorullah Posted on Jan 01, 2018
I need HTC 830 Camera - HTC Cell Phones
Needle threaded is stuck in up position will not return 830 bernina
Bernina 830 Record??? Or newer Bernina 830 computerized?
If it's a Record, could very well need a good cleaning and oiling. Older mechanical machines need periodic lube to keep them running smoothly and quietly.
Wheel on right side that controls the needle up and down is very tight...
My Bernina 830 will not switch stitches. It says the number but shows straight stitch and sews straight stitch
Is it a new 830 computerized model or the older 830 Record mechanical?
If it is the 830 Record, it needs oiling--1-2 drops of good quality sewing machine oil (specifically concentrate on the stitch selector lever and oil the metal parts that move against other metal parts) Do NOT oil the cams, plastic gears, any rubber parts, ie belts, bobbin winder wheel.
Bernina 530 through 830 Record Oiling Diagram
Need to turn off shuter sound for camera on htc phone
What model is your HTC? I have an HTC ONE, so I'll use mine as an example. In the camera app, press the 3-dot menu to drop down the settings, scroll down to shutter option, and uncheck where it says shutter sound.
Oct 20, 2013 • Cell Phones
Screen on my olympus stylus 830 went black
You do have a one year factory warranty from date of purchase - suggestion is to send it in for evaluation as it could be a problem with the chip inside the camera that controls image processing. It sounds like that chip may need to be replaced. You can call Olympus Customer Service at 800-622-6372 option 2 and then option 3 to discuss the repair process with them.
Where to go to find software for my i 830 polaroid camera??
see if picasa will down load your pictures or buy a card reader and use the usb to down load your pictures
For formating card
Try http://lclane2.atspace.com/olformat.html
The Olympus C-830L camera is the same as the D-340R
2answers
I need help
If your computer is Win ME/2000/XP   you do not need software from a disk
Windows can do it all by itself
Simply plug the camera into the USB port and Windows will put up the scanner camera wizard - follow the prompt
Olympus camedia C-830L.
Hello
Problem formating smartmedia memory card olympus c-830 l . Model card M-8P D3V20 , 8 Mb.
No user manual c-830 L , no guide for formating .
My format card for pc - fat 32 and desastre .
Please , information for formating card .
Sorry , no speek english .
My adress :
Nicolae Grozav
Loc. Arbore nr. 769
Jud. Suceava - region Suceava
Cod - zip 727015
ROMANIA
Tel. +40 0230/539336 or +40 0742/551259 - mobile
email : [email protected]
Yours sincerely , Nicolae Grozav
Top HTC Cell Phones Experts
NOEL
NOEL
john h
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
