Cars & Trucks Logo
Hi i bought a Pentax smart pump an i don't no anything about water pump so i will like to no y everytime i put on the pump it start up working fine fullin up my water tanks den 5 to 10 minutes it cuts off an will not come back on unit i pull the plug an put it back on
Hi my name is Neal. I have a 2004 kaw 900 stx jet ski with the heat light flashing and when I put it in the water it will NOT run full throttle and cuts out from start. However out the water with flush...
I'm no expert on jet-skis or anything but it sounds like you may have a "water-pump" issue. In the water it bogs and cuts out..... but put a "flow" of water from a "hose" and it runs fine out the water, the flow of water surpasses the water-pump and allows flow to cool the engine. I would check water-pump before I would go too far with it. Hope this helps, Jesus loves you, John 3:16-17 (KJV)
1helpful
I have a 90 yamaha square nose superjet . It starts up fine outta water but once I put it in water it's kinda hard to start and when It does start if I put any weight in the tray it blog / stalls out...
I take that the vehicle is a jet ski. They work by the engine driving a centrifical pump to expel water at pressure at the out let. If it runs well out of water there is no load on the engine I would be checking things like spark plugs, timing exhaust blockages Corrosion in water jackets in exhaust as when it is water there would be water cooled exhaust.
1helpful
I have a 95 Honda accord I recently put in a timing belt a water pump got a new battery but now the car won't start at all. Here is the story the car was sitting for almost a year before I got it I had...
fisrt of all your alternator is not charging well n there is something draining your battery but can u explain 2 me more am willing to help you
What could be my problem with my 2000 blazer not wanting to crank in right off the bat?
  • So your saying you turn the key to start and nothing 3-4 times? What I am understanding is it don't want to start for a few times.
  • I'd sure like to know what the fuel pressure readings were. There is a pressure test when it is running and when the vehicle is off to make sure the pressure is maintained when the vehicle is turned off. If pressure is not held when the vehicle is turned off then it will do exactly what you are saying it does. Which could be a few things, fuel pump and fuel filter for starters.
  • Possibility of some bad gas of gas with more water than should be in it and the water is freezing just enough to slow the flow of fuel down. I like to use "heat" in the colder months for just this reason.
  • Are we on the same page?
98 gmc jimmy only start when primed at the throttle body then runs fine until shut off then needs to be primed again to start
This happened to me I had to spray Starting fluid everytime eventually. Starting fluid wouldn't work after awhile. Its the fuel pump. Even though it comes on and works its not producing enough fuel pressure to start the engine. It's probably giving about 12-13lbs of pressure but it needs atleast 14lbs. of pressure. And a word of advice to buy a ACDelco original fuel pump if you don't want to have to replace it again in 1-2 years, it's more expensive but will last.
1helpful
2answers
1997 achieva hard to start sputters, runs fine
sounds like the fuel pressure regulator,also make sure the fuel pump and sending unit are working properly. happened to 99 olds of mine! good luck
Severe Over-heating
Hi there. I had a lincoln towncar around the same year do the same thing and it was the waterpump. I doubt its just the gasket since it is overheating all the time now. The pump on mine was for the 5.0(302) it was 28 dollars but it was not real easy to change as far as waterpumps go. I would get a hayes or chiltons manual if your not real farmiliar with these before attempting to change it.
Top Smart Experts
ROBERT GARCIA
ROBERT GARCIA
ZJ Limited
ZJ Limited
Are you a Smart Expert? Answer questions, earn points and help others
