Try this link
Toro LX Lawn Tractor Service Manual Page 2
SOURCE: Need help finding the PTO and the solenoid in a
PTO on tis machine is located inside of trasmission,switch on dash.Solenoid/coil is located on rear of trans at the top.When energized the coil magnetically moves a valve inside of trans an allows high pressure fluid to engage clutch.In 15 years with Deere I only had too replace 2 solenoids and no clutches.
SOURCE: My Cub cadet pto cluch bearing is froze up on my 2518 lawn tracto
A medium length extension (stuck through the grill), a swivel and an impact is all you need to remove the pulley with the frozen bearing. It's just a bolt, a washer, and a lock washer holding it on. You just need to remove the pulley to see if the bearing is stuck. Take the pulley to your local shop that can press bearings and you can be up and running for $20 dollars instead of $300. Here's a diagram I found on partstree:
http://www.partstree.com/parts/?lc=cub_cadet&mn=2518-48+Tractor&dn=0043700012
SOURCE: my lt150 lawn tractor is backfiring when the pto
Sounds like the float is bad - what happens is the float sits just a little off and when you add the demand of more fuel it skewers the RPM by starving the engine.
Try removing the carburator and either adjusting the float by bending the tab or replace it. As part of this repair i suggest you just replace the needle and seat as well if they are over a year old.
Thanks,
Gary @ Fix Ya
SOURCE: looking for a diagram of
this link will help you http://www.manualsonline.com/https://www.shoptoro.com/Comergent/en/US/adirect/Toro?cmd=ToroOnlineModelLookup
SOURCE: What attachments can I use for a manual pto lawn tractor?
it would depend on the model/size of the machine i have seen that the snow blower attachments don't work very well on any rider i don't think sears had a tiller for anything modern and what you would pay for most any attachment you can get a stand alone version cheaper if you want a work tractor get a wheel horse a old cub or deere tractor not a riding mower that is to weak to handle the work out
