Cars & Trucks Logo
STEVEN GRACE Posted on Sep 06, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
1200 BAKKIE OVERHEATED, WATER PUMP IS THE CULPRET, NOW SHE WONT START, WHAT COULD BE WRONG
  • STEVEN GRACE
    STEVEN GRACE Sep 07, 2017
    how do you replace the front welsh plug on a 1200 fiat strada bakkie. And whats the right size plug. 51mm. thanks
richie46
Level 3:
Top Expert:
  • Cars & Trucks Master 12,962 Answers
  • Posted on Sep 06, 2017
richie46
Level 3:
Top Expert:
Answers
12962
Questions
Helped
2946248
Points
58151
When it overheated it is possible that the motor may have gotten damaged. Does it crank - if not it is frozen. If it cranks some other part may have been damaged. Check for the obvious - spark and ignition coil.
Vernon Taylor
Level 3:
  • Cars & Trucks Master 7,446 Answers
 Vernon Taylor
Level 3:
Answers
7446
Questions
0
Helped
1960392
Points
26207
Depends how hot it became depends on the damage caused - overheating is a very broad term that is often used when "cooked" would be more appropriate.
Mild overheating can burn the oil from cylinders robbing them of compression but seriously cooking an engine can destroy rubber components, weaken valve springs, melt pistons and create serious distortion of metal components.
Only a back to basics systematic approach can estimate the damage...
3 Related Answers
caroldon
  • 17130 Answers
  • Posted on Aug 15, 2010
SOURCE: The water pump went out and the car overheated.
Please remove all the plugs and check the firing on all individually. Now see that your fuel lines are good and make sure there is fuel distribution into the cylinder., If there was an over flow make sure that it was pumped out when the plugs weere removed. Now since you have confirrmed that the cylinder has not cracked, the plugs must be set back and tried. Hope the fuel pump is working fine- since you had a very hot engine, otherwise this can be the culprit. Hope you try this out. Good day
Anonymous
  • 8 Answers
  • Posted on Jul 29, 2013
SOURCE: 1997 Chrysler lhs overheated..replace
if your spark plugs are wet that's either a blown head gasket, or a warped head, that's the only way water could get into the cylinder
Dan B
  • 36 Answers
  • Posted on Jan 27, 2015
SOURCE: My Toyota Bakkie 2000l vvti wont start after fitting new o ring.... Water leak
What O ring? On cylinder head? Do you see water floating in oil after draining oil pan? If water enters exhaust system, catalytic converter (assuming there is one), maybe clogged.
Car overheated very fast, now there is a leak and the car wont start, could it be the water pump or is it more serious
Well it would depend on why the engine won't start.
If it overheated and the head gasket blew out, you may not have enough compression to start the engine.
A water pump leak would not prevent the engine from starting.
Will temp sensor cause vehicle to lak power
The temp sensor could send the wrong signal to the computer, but the fuel mixture would be very rich or very lean at any speed.
Hi, Our ISUZU 280 KB doesn't get diesel through..if you start the bakkie it initially starts but the engine quickly dies even if you floor the accellerator. If you press the "manual diesel pump"
Blockclogs easily if you get some water in the diesel.age in fuel system. Remove both pipes from tank to pump and blow. If clogged replace. Also check fuel filter. That thing
On a 2006 1.3 Rocam. After a broken heater hose, the engine overheated, and I didn't notice until the bakkie lost power. I replaced the head gasket, with no success. The engine still overheated.
Have you checked to see if your fan is working ?
After performing your repairs, did you bleed the coolant system ? One way is to run vehicle with heaters running to make sure that air in the heater core / hoses is bleed.
Overheated and won't start up
if it wont crank, you will need to have the concern diagnosed with a scan tool. preferably a vw scan tool at the dealer. the reason it overheated is becuase the water pump impeller is broken or stripped out and is free-wheeling on the pump shaft.
Car Won't Start
More then likely when you replaced the water pump and starter you might have installed the starter wrong or it's defective if it used to start before the repairs u did but now wont. Also, Why did your car overheat in the first place? might not be a problem with your water pump but perhaps a bad headgasket. Might wanna get that checked.
My car overheated instantly and then it had a grinding sound when i tired to start it. It will start at all. Could a bad water pump cause it not to start? Or, what's the problem and how do I fix it?
the waterpump may have went out, leaked out all the coolant, and depending on how badly you overheated your engine, you may have serious problems as to some engines dont handle extreme heat very well. you might want to get professional help
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
