SOURCE: my robinair isn't working and shows high pressure
This is a common problrm of Robinair 34700Z series machine.so don't worry just do the following :- 1# Verify the ISV tank is not overfilled.if full,remove refrigerant from tank. 2# Verify if there is high pressure in the tank.Purge excess air from the tank manually.( Open air purge hose from the tank,then press tank valve as needed) 3#Check the high pressure switch for proper operation,if not then replace high pressure switch.Hope this will solve your problem.
SOURCE: Robinair 34700z not filling source tank / slow recovery
Please check the following:1# For not filling ISV tank (internal storage vassel) Check tank fill solenois,it's may need to rebuild or replace.2# For not compleet recovery,Check & make sure your machine compressor haveing 13''HG suction.if not then you have to replace new compressor.3# Check 13'' vacuum sensor is working properly.
NOTE:PLEASE CHECK FILTER CAPAICITY,BECAUSE EVERY 68Kg/150Lbs OF REFRIGERANT RECOVERY YOU MUST CHANGE SPIN-ON FILTER.
SOURCE: Robinair model 34700Z / There is power on the
Please check harness continuity between the 15 Amp circuit breaker connector (P11) on the back of the control module.If continuity checks good,replace the Control Module.Hope this will solve your problem.
SOURCE: I need to replace the filter in my Robinair 34700Z
Press the main menu key,then upper arrow & go to "Change filter" option,then press "Yes" key & now follow on screen message(Do not skip any option while active ''change filter'' option).
Filter located on back side of the machine & fixed with the manifold assy.it's long black color & you may see the sticker with part no# 34724 (spin-on filter dyer).
For user manual you can try to robinair web official site www.robinair.com
Hope this will help you.
SOURCE: The high pressure unit is disabled in my Robinair
This is a common problrm of Robinair 34700Z / 347002k & 347112k series machine.so don't worry just do the following :- 1# Verify the ISV tank is not overfilled.if full,remove refrigerant manually from tank. 2# Verify if there is high pressure in the tank.Purge excess air from the tank manually.( Open air purge hose from the tank,then press tank valve as needed) 3#Check the high pressure switch for proper operation,if not then replace high pressure switch.Hope this will solve your problem, if so please vot for it
