My At&t tilt always says that the SIM card is missing even though the sim card is inserted. I have tried attaching tape to the rear of the sim card to no avail. please assist
First All Check: 1.Confirm whether same sim card is working in other h.s or not. 2.Make sure the sim slot is o.k. only try these two. 3.If all the above steps fails, check the SIM card connector pins for damage. if so try to get serviced. 4.if ur sim card is good then it is problum form sim card ic u have u raplace it with SMD. u can make it jumper mean u can fix this prob with out sim card is for this contact. 5.take sim connector slight up by pin then cheak by inserting sim. 6.hot air gun on sim i.c. then cheak it. Last Option: IF make sure that the sim card hasn't been damamged at all sO Please You Go to Service & Sim Office and Get the Duplicate Sim Same Your No From Office Oprator Problem will Solved Quickly
Solution, try putting a paper behind the sim card before placing it in the cellphone. The paper adds thickness to the sim card and makes it touch the connectors in the cellphone.
This problem is due to your phone's sim card IC malfunctioning. It may get damaged due to phone dropping gently into rough surface and its crystal structure may break due to it.
for any queries
mail to [email protected]
well... seem like you phone has got locked from the network may be accidently in case of stolen better check you service provider and if they say every thing is fine try to flash your mobile .it has some perticular number to flash it try these number *#7780# (password 12345)
