Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; to which you want set-up codes; in the "Search box at the top right of the display window" to get gathered related posts.
SOURCE: need code for universal remote
I don't believe ESC is supported - most portables are not - as far as the Relissys try code 580
SOURCE: I have a PHILIPS SRU3004/27 Universal 4in1 remot
Download just the Philips Codes booklet for the Philips SRU3004WM/17 here. I have included the full codes booklet in a PDF format.
Your welcome. Make sure you Thumbs up me!
SOURCE: Topfield Universal RC code???? Help!
Try this site and look for codes by your device Brand. Not with remote Brand. You will get setup details too.
For more details, type in the site name "Electro-help" to your search engines' search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as Service help to electronic home entertainment equipments. Pull up older posts. You can get all details. You can locate it either at the bottom part of first search page, or at the top of second page. Detailed descriptions are there to help you. Sometimes, clicking on advertisements by the side and bottom of each post might help you to get details about the availability of spare parts; price etc:-
SOURCE: i need too know the code for invoca universal remote 4in1 code for this tv
Judy, remote codes links below. http://remotecodelist.com/remotes/old-index.html
https://www.google.ca/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&cad=rja&uact=8&ved=0ahUKEwjghcjT_InLAhWFpB4KHfs7BK4QFgggMAE&url=http%3A%2F%2Fforums.xfinity.com%2Ft5%2FXfinityTV-and-Equipment%2FEmerson-brand-TV-remote-codes%2Ftd-p%2F784589&usg=AFQjCNE9664m-g31YDTin1VV4e5wQWVlmQ
https://www.google.ca/url?sa=t&rct=j&q=&esrc=s&source=web&cd=4&cad=rja&uact=8&ved=0ahUKEwjblf31_InLAhVHHx4KHedsAX0QFggvMAM&url=http%3A%2F%2Fwww.remotecodelist.com%2Fremotes%2Femerson%2Femerson.html&usg=AFQjCNFZ1Z-tCbIt3cXSaonWtADiBlxeHw
https://www.google.ca/url?sa=t&rct=j&q=&esrc=s&source=web&cd=8&cad=rja&uact=8&ved=0ahUKEwjblf31_InLAhVHHx4KHedsAX0QFghBMAc&url=http%3A%2F%2Fwww.cnet.com%2Fforums%2Fdiscussions%2Femerson-tv-code-for-universal-remote-574545%2F&usg=AFQjCNGJbdSEQB30EPlaGCoYvSjlng0E9A
SOURCE: i need code for universal asda control for a onn tv
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://electro-medical.blogspot.com/
