54c with drive shaft
SOURCE: front spindle caliper mount holes stripped,any fixes
they make heily coils to either down one size or up one size .make sure you put red lock tight on heily coil when you instal in the striped hole.make sure holes are CLEAN.
SOURCE: which way do you turn the crankshaft pulley bolt to loosen it?
It turns left (counterclockwise) to remove. An impact wrench is best if you can get one on it.
If you don't use an impact wrench, you may need to somehow keep the crank from turning when you loosen the bolt.
One way is to pull the belt tighter to put more tension on the crank pulley.
There are other creative ways I've used. If you have any trouble let me know.
SOURCE: trailing arm troubles
Honda has a wonderful way of making so that you need to but the parts new, They don't want you to swap them. This is how they make their money, By making our live difficult.
SOURCE: cant remove wheel bearing assembly from the spindle 1996 chevy
check the front of the hub assembly, just to double check and see if there is a cap on it with a crown nut behind it. It should not be stuck to the spindle at all and this is the most likely cause. If there is a crown nut there, there will be a cotter pin you have to remove to take the nut off.
