The manual I have has 3 languages but NOT English--which is what I read/need.
SOURCE: Change language to english
Solution #3 worked for me, but the first part "choose the 9th item' wasn't accurate b/c the menu is all pictures. However, this corresponds to the Setup menu item which looks like a small screwdriver and wrench. After that, it was the 6th item down like it said.
Go to the menu by clicking on the menu button there you will get an option to set the language..
"language" in japenese is "言語"
SOURCE: i have a daisy powerline 856 .177 cal pellet
do wat I did,Go to your local ace hardware store and look for the o-ring seals.I Replaced mine that way.Just take the ring you remove from the chamber and take it with you so you can find the right part
SOURCE: I need to change language in Nissan Cedric 2003
want to change from japanese language to english language? is it possible? how?pls rpl
SOURCE: I have a Daisy 2003
The slide pin needs to be in the up position, and yes you have to load the magazine with the pellets one at a time.
