I have a belkin f5d8233 4v3 modem and a Arris SiS 900-Based PCI Fast Ethernet Adapter it was workin about a mont or two ago before i got this problem and without the router being plugged up and the modem being plugged straigth in th computer i have a connection. but when i try to plug the modem in the WAN port on the modem and the computer in the LAN port on the modem, i dont have a connection and the router wont recognize the modem the icon blinks orange i've tried callin the belkin wupport but they didint help. i've tried go to the router console thingy and that didnt let on there COULD SOME PLZ HELP PLZ PLZ PLZ
Hi! I will be more than glad to assist u in this concern..That is right! if u bypass the router it will work, the reason why the modem wont talk to the router bcoz the router is not properly setup.. if you are using a cable modem from ur cable company provider- u need to do a mac clone on the router u have to clone the mac address of ur computer. normaly the mac of ur computer is the one register to your cable company and on the setup page of the router just selct on the internet setup, dhcp after clonning the mac address of your computer. u need to connect ur computer directly to the router and then after doing the process connect the router to the modem. if u are using a username and password, u have to use the pppoe settings on the router, if ur isp set a static ip , set it up to the router, to check the ip setting of your isp.. connect the computer directly to the modem and check if u have internet.. then click on start, run and type cmd,it will give u a dos prompt and from there type ipconfig/all and it will show u the ip address, subnetmask, default gateway, dns server.. I hope this will solve ur concern..
