Look in the Miata forums. There's a huge amount of Miata fans that can either send you a copy or direct you to a link were you can download the manual. Here's a link that may work for you:
https://forum.miata.net/vb/showthread.php?t=446293.
Good luck! I hope this helps somehow... :)
SOURCE: Mazda miata radiator replacement
For myself, if I were to replace something like that, I would (as I did in my 87 RX7 TII) a performance radiator. Koyo the trusted brand is my suggestion though probably more expensive.
http://www.amazon.com/Koyo-R1139-Radiators-1ST-53mm/dp/B000ECN3OO/ref=sr_1_2?ie=UTF8&s=automotive&qid=1239937960&sr=8-2
or ebay
http://cgi.ebay.com/ebaymotors/KOYO-ALUMINUM-RACING-RADIATOR-MAZDA-MIATA-90-97-1st-GEN_W0QQcmdZViewItemQQ_trkparmsZ72Q3a1205Q7c66Q3a2Q7c65Q3a12Q7c39Q3a1Q7c240Q3a1318Q7c301Q3a1Q7c293Q3a1Q7c294Q3a50QQ_trksidZp3286Q2ec0Q2em14QQhashZitem170321509131QQitemZ170321509131QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
Just be sure to take measurements where needed. Other than that, most radiator swaps can be a DIY project if you have a few hours and are handy with a socket wrench, screwdriver and pliers.
SOURCE: 1997 Mazda Miata button with red light lower left Dash
That toggle switch is for the security system. That year miata never came with any switches for the soft top of any kind. Most likely that is an aftermarket alarm system. Most factory alarm systems do not come with a toggle switch.
SOURCE: where can i find the engine number of my 1997 Mazda miata
Same as the VIN otherwise it is on a plate riveted to the passenger side of the oil pan.
If are you talking about the Engine Model number it is a BP-14
SOURCE: what could it be when my engine light came on - I
Have computer diag. done on your car, computer pick up a bad signal from one of your engine sensor, have it check out asap.
Testimonial: "Thanks for the quick response "
SOURCE: I just bought a 1997 mazda miata with no manual i
The car alarm was not part of the car as it left the factory, it was fitted afterwards. You'd need to find out what make and model your alarm system is, at least the make, and google for an instruction manual of that alarm. The make could be on your key fobs, or maybe there are stickers on the windows?
