SOURCE: contact lists in samsung tocca
the only way i have found is to fully reset the phone ( back to how a new phone comes) , copy all contacts onto your sim, and any other stuff on your phone you dont want to lose. like photos prob best to plug it into PC and make a copy that way.
just in case i removed the sim from the phone and restarted it in no sim mode.
then dial
*2767*3855#
replace sim, and there gone
this is a bit of a pain doing it like this but it gets you out of any difficuilt situations if your texting people you should not be !
SOURCE: ps3 friends list
First go to settings and have the PS3 update the system's date and time via internet. If that fails, try rebuilding your database (It's helped many people in the past).
This is how to rebuild your database:
1. Turn off your PS3.
2. Press and Hold the power button down; the system will turn on and turn off once again. Once the system is off then take your finger off the button.
3. Press and Hold the power button down again until you hear 2 consecutive beeps.
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button.
6. The Recovery menu will pop up.
7. Select the Rebuild System Database option.
The Recovery Menu supports the following options:
• Restart System: Restarts the PS3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the Operating System for the PS3 (doesn't delete anything).
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Updates the PS3 firmware to current version.
***** WORKED FOR ME *****
SOURCE: friends' yahoo messenger ID blocked.Can't add it to my msgr list!
I have used Zak's nobuddy before - it has been updated to work with yahoo's newest protocols.
Test: (A) I have 2 yahoo ID's - I added each to the other:
(B) I use Yahoo Messenger version 9.0.0.2162
(C) I was invisible mode at all times on each ID
1 I then got this zak nobuddy to remove one from the other:
2 It worked (although it left no message - I was simply gone).
3 I then performed the normal add request - this too worked fine and I was added again as soon as ID2 accepted.
You say it's blocked from your contact list:
I would check from messengers menu bar
messenger/ preferences/ ignore list and see if your friends ID is in there.
SOURCE: how do I add a site to email safe list
