Ok.. ive been kinda looking everywhere... i need the paint code for my car, its a 91 ford tempo gl, code on door is k2... but thats not my color, mines that light baby pale blue.... anyone? code and color name if pos. thanks don
You should always use a good primer first after sanding it all correctly ...the paint code is in your vin number ....usually ....you should be al to buy the right paint for it ....good luck
If you are sure it is white smoke and the car overheats or looses water,The head gasket is bad.
Or It's valve seals or rings smokes (but the smoke would have a blueish tint)
All Ford vehicles have the paint code located on the drivers side door jamb. Open the door and look on the lower section of the sticker that has the production date and vin number.
you need a wire harness for your car you can buy them at most auto parts stores make sure and buy the one for your make and model they should have instructions and the wiring diagram most harnesses are color coded and pretty simple to install
I would check the alternator again, it apparently isn't charging the battery with engine running. You need a volt meter or amp meter to test this. Also does the battery discharge when the car is not running?
