I can't figure this out, was driving my contour hit a big bump and my car sputtered and died. wont start now no sound. Key very hard to get in and out of ignition.
SOURCE: 1998 ford contour start up, alternator? battery?
Sounds to me like you drained your donor battery to the point where you can't jumpstart your car anymore. If you jump a car and it runs for a little bit but then dies that means your alternator is toast. If it was a bad ground, you would see sparks or a fire... Your battery only starts the car, once it is running your alternator supplies the electrical system and charges your battery back up. If you need more in depth help in replacing the alternator go to www.contour.org and get on the forums.
SOURCE: 93 honda civic ex sputtered and died while driving
Is there any white smoke coming out the exhaust? Sounds like the same problem my friend had when he warped his head on his 91 civic. Any overheating at all? Otherwise another guess would be maybe a bad catalitic converter that clogged up. Hope this helps any, good luck
SOURCE: 1986 Ford Bronco II sputters and then dies it seems if gas tank
i would repace the tank and sending unit
SOURCE: The battery in my car keeps died, so I jump it then it dies again
if you have a multi meter disconnect positve battery terminal and put red wire to battery and black to battery cable put multi meter on resistance should be 0.005 or less if more then check for things that may be plugged in to cig lighter etc turn door lights off etc dont turn key on any more than 0.005 will drain battery
