SOURCE: DBXR453ET3WW Electric Dryer Won't shut off unless on timed cycle.
hi thanks for the question in the ge dryer theres 2 elements so if one is not working you only get half heat i would check the heater thanks the appliance doc
SOURCE: LG all in one washer dryer fills with water on the drying cycle
the unit is made to bring water in in the drying cycle ,,the water dont touch the clothes..the water is to take the lint away and to cool the drum,,you must remember that you can was 22 pounds but you can only dry 11 pound..so you must dry about half of what you wash..and drying the 11 pounds it will take 3 to 4 hours,,no exhaust...
SOURCE: during the drying cycle, the dryer door opens
Chances are the little plastic latch keep is broken. Look at the door and locate a peice that will press into the front area where the clothes go in.
Once you see it, check the keeper and see if it is broken. The door should not just pop open.
SOURCE: My GE Dryer model DWSR483EA1ww will not stop & doesn't dry quick
first thing you should do is check the flow of your vent, a clogged vent can cause all your problems check it outside while the unit is running you should get really good flow compare it to the flow of the dryer with the vent hose off the dryer completly. they should be fairly close or just run it with out the vent hooked up to the vent if you have an electric but not with a gas dryer
SOURCE: During a drying cycle, the
This was a concern on some whirlpool and kenmore dryers. The fix was to replace both of the catches (the part on the dryer front panel ) and the latches (the part on the door) as well as a redesigned door gasket. Im sure if you contact Whirlpool customer assistance they would be able to supply you with a part number for the repair kit....
Mine did the same thing. Door switch was fine. There is a non-replaceable relay on the PCB that got stuck. Luckily a tap on the relay freed it, but it will probably happen again. May have to replace the PCB next time.
Just had the same problem. Black relay (Black wire and blue wire) tapped it and got it working correctly. I'm guessing it's pretty common.
Having the same issue.....How do you access these relays?
