If the red brake indicator light is on , Have someone at O" reileys put some brake fluid in the master cylinder. Don't worry about the ABS light. is the brake pedal soft? If so the brake system will have to be bled to remove air from system. Do not put this off. tonight if possible. Talk to Kevin Hi-Way 17 by wal-mart.
You must have the system scanned with a special scan tool to see what ABS fault codes are present and then based on those codes diagnose the problem.
