Blenders Logo
e
ellen Posted on Feb 21, 2017
Blendtec error 2, and base sounds like a screw is loose and moving around in it
Blendtec Connoisseur 825 - Industrial Blender. Does anyone know how to reset to factory defaults? Cannot get to menu by pressing 2 + 4 buttons.
Question edited for clarity, 'make model (what it is)'.
Question moved from Office Equipment to correct category.
The manual says that adding a new Profile reset. For other errors it says to contact a local service agent. There are 6 mentions of 'Reset' in the manual.
https://www.manualslib.com/manual/869873/Blendtec-Connoisseur-825.html?page=14&term=Reset&selected=6#manual
Programming Guide to units prior to 2018. (found by OP)
https://blendtec.uk/wp-content/uploads/pdf/manuals/Blendtec-Cyclechart-C825-ENG.pdf
I have a Kitchen Champ by K-Tec and the gear shaft broke. I have looked and looked for a replacement. Do you have any idea where one can be found please?
Question edited for clarity, name of maker.
Question moved from Cars and Trucks.
The company handles these as Blendtec now. The web site is at http://www.blendtec.com/default.aspx Maybe this will help:
Customer service and sales are available from 8:00 am to 5:30 pm (MST) M-F.
I just talked with Blendtec about this issue, since I had the same problem. I asked if there was a stronger drive shaft since my previous Kitchen Champ model had a different, sturdier drive shaft that lasted about ten years.
The company representative explained that the new drive shaft is designed to break, but that's to save the motor. If the stress on the drive shaft could damage or cause excessive wear to the motor, the drive shaft breaks instead.
She also recommended using just enough flour so that the bread dough pulls away from the sides of the bowl. The reason most drive shafts experience too much stress is due to too much flour in the recipe.
To replace the drive shaft, go to http://www.blendtec.com/Parts.aspx or call Blendtec at 1-800-Blendtec
The only part that will work for the Kitchen Champ is the Drive Shaft (Champ). Apparently, the German drive shaft -- which looks like the one from my old Kitchen Champ -- is not interchangeable.
Since this is my second Kitchen Champ and my previous one lasted over ten years, I'm delighted to understand what went wrong. I'm hopeful that using less flour will prevent another problem. And, I'm very pleased with how helpful Blendtec was, explaining this to me.
All taken from here.
https://www.google.com/search?q=kitchen+champ+by+K-Tec
Get a manual for blendtec ES3
i have blendtec blender model ES3 they have problem always showing overload?
1helpful
2answers
Does anyone know how to reset a Blendtec ICB-3 to factory settings?
ust removing all power from the machine for 15 secs or more should reset it.You can contact Blendtec here, Not a solution I know sorry. The manual is here http://www.blendtec.com/Resources/A3-31E-BHMV/Connoisseur%20Manual.pdf
you can contact them here
http://www.blendtec.com/contactus.aspx
Jan 03, 2011 • Blenders
1helpful
My blendtec blender doesn't blend as well as it once did. The motor seems to be running fine, but I am not sure if the blades are spinning properly.
You have already found what is the problem the blades.
The blades after a lot of working hours with ice they have mainly three problems.
One the sharp adjes have created a lot of teeths and are not so sharp any more so the blending is not smooth anymore.
Second problem they have loose a title so they have move from corect place some milimeters and this change the wave motion and again the beleding is not so smooth as before.
Third the blades are secure on an axis which is located in two bearings which have een wearing out so the rotating motion of the blades again is not so smooth as before.
So if you are not able to fix the blades kit or to find someone in your area to do it profetionaly and cheap one good idea is to buy a new blades kid.
Good luck
The blades on my blendtec jug are stiff, any way to loosen them?
What you need to do is turn them by hand each time you use it, before you put your food in. Sugars and other deposits are often left around the blade assembly when you mix smoothies and stuff. Often this sugar is difficult to clean. Turn them by hand first to break the sugar molecules, then when you are done I would add 2 inches of water and a drop of soap. Run it for about 20 seconds and rinse. That should help the next time you use it. It also helps to use it daily. It keeps the molecules from hardening.
1helpful
2answers
Blendtec replacement jar
You can also go to http://veggiesensations.com to buy blendtec total blender parts. Hope this helps!
2helpful
3answers
There is a leak in the caraffe(or jar). It is at
Common issue with all of these carafe's. Once the jar starts to leak the bearings are shot and it is time to replace the jar. The bearings are non-replacable. Bad design in my opinion. I was able to get my last jar (I have been through 3 before the 5 year warranty went out) to last by hand washing and not putting it in the dishwasher, but after 4 years of use on this jar it failed too.
2answers
BLENDTEC BLENDER WONT WORK WATCH DOG TIME OUT?
That is a motor issue, you need to contact Blendtec customer service. They will let you know if it is still under warranty. 1-800253-6383.
7helpful
2answers
What to do with the Total Blender when overload appears?
The product has a 3-year warranty:
A reading of “OVERLOAD” indicates an overload on the motor. Turn off
and unplug the unit. Plug in the unit and turn the motor on again to clear the
over-load condition. Check the blender jar for blockage. If overload condition
re-occurs, contact your Blendtec service agent.
Top Blendtec Blenders Experts
Mike Cairns
Mike Cairns
ADMIN Andrew
ADMIN Andrew
vince
Are you a Blendtec Blender Expert? Answer questions, earn points and help others
