The exact location of the Bluetooth settings on your Luxor 55" TV can vary depending on the model and the operating system it uses. However, here are some general steps that can help you find the Bluetooth settings on your TV:
Turn on the TV: Press the power button on your Luxor 55" TV to turn it on.
Access the settings menu: Press the "Menu" button on your TV remote to access the settings menu. This may also be labeled as "Settings," "Options," or "Tools."
Look for the Bluetooth settings: Scroll through the menu options and look for a section labeled "Bluetooth" or "Wireless and networks." The exact location of this option may vary depending on your TV model and the operating system it uses.
Enable Bluetooth: Once you have found the Bluetooth settings, toggle the switch to turn on Bluetooth. You may also need to set the TV to "discoverable" mode so that it can connect to other Bluetooth devices.
If you are unable to find the Bluetooth settings on your TV or are having trouble connecting your Bluetooth devices, you may want to refer to the user manual or contact Luxor support for further assistance.
To find the Bluetooth setting on your Luxor 55 inch TV, press the "Menu" button on the remote control and select the "Settings" menu. From there, select the "Network" option and then select "Bluetooth". This will display the Bluetooth setting which can be toggled to "On" or "Off".
If they are cordless headphones powered by Bluetooth, you just need to pair them again.
If they are wired you may have worn out the headphone socket. Have the socket replaced, get a Bluetooth Dongle for it and Wireless headphones, so there are no moving parts and no wires.
There is a video in this link that should help you.
In the television settings you have to add the Hub SSID and the WPA password. It isn't like Bluetooth in that it searches and finds. It also has to be physically connected with a cable, or it the television is wifi connectible, you have to choose. Find the television manual online Google
look at the back and see if there are 4 threaded holes around 6/8 mm in diameter over and area of around 150-200 mm square or rectangular
go to a retailer that sells that brand and ask it it is possible
4 hours ago - first turn on bluetooth and goto bluetooth settings and goto authentication and turnoff it.then bluetooth is connected ... when it asked for the pincode ...
? 0:29
https://www.youtube.com/watch?v=XrVJZtkV4sc
Aug 25, 2011 - Uploaded by jasonmctavish24
I bought this tv, now the picture is good for blu rays and my xbox etc. But it says 'DAVE' in really faint ...
