SOURCE: how to change the battery on a Nixon Scout Watch?
Strap is attached to case by spring pins. Both ends of spring pin are inserted into holes into the case lugs,
. Take the knife and push the spring pin end inwards to release the watch strap.
Do not forget to rate, please.
SOURCE: battery change for Nixon Kink watch
You have to open your watch caseback. Undo the battery holding contact, get the battery out and memorise the writings on the battery. Buy exactly the same one and replace it in the backwards way you took it out.
SOURCE: Add link to the wrist band on my Nixon
you can find a exper in you real life or in the watch shop..
center: SR616SW sides: SR416SW
SOURCE: user manual for nixon delta pu watch
Here you go,
http://www.nixon.com/manuals/nixon_delta.pdf
