I am having an issue with my car !
My drain pipe for the AC is blocked again .
How do I konw because the carpet is wet near the centre hub of car under the dash.
My AC works but I noticed the heater not working due to the water sitting on top of the heater. I also noticed the demister was blowing cold and water vapour. So my demister on the front window was fogging up the windscreen .
Get a mechanic to check the AC drain pipe !
SOURCE: Heater, AC & radio suddenly stopped working....
Fuses are in the kick panel on the passenger side. If it blows again, you will need to find the malfunction (don't put in a higher rated fuse) Most times the blower motor will cause fuse failure as when the motor gets older it begins to draw excessive amperage...but don't change it till it is actually verified as being bad.
SOURCE: the blower motor for my 2005 Suburban suddenly
Check voltage at the terminal that connects the blower if the problem is the current blower because eventually the brushes wear out
SOURCE: heater only blows cold air
Check your rad and make sure it is full. Wait til truck is cold before removing rad cap.
SOURCE: my ac was working fine
There is a blender that controls the air flow to go through the heater core for heat, and the evaporator for AC. It very well could be stuck.
You maybe able to try and get it to get unstuck by running the cars AC and switching from heat to AC back and forth and see if it gets unstuck. Just turn it on full blast and go from heat to cool.
If that fails, then you may need to service it. There should be a Lever Marked VENT under the dash, usually by the Brake
and other pedals on the Driver's Side. Close the VENT and that will
stop the Air from coming in and leave the A/C Blowing through the
outlets(Vents).
I also read this online if you have an electronic climate control. "On
climate control press off and heat button and let go quickly. Then
press automatic. The display will start rotating eventually displaying a
code 025,125 , 024 etc. Then press defrost to stop. You may hear blend
door operating atb that time. It worked for my climate control."
