Car issues
WHAT CONDITION ARE YOUR BATTERY CABLES ? THEY MAY SEEM OK, BUT SOMETIMES REPLACEMENT IS NECESSARY ! BATTERY TERMINALS MUST BE CLEANED, SMEAR SOME VASOLINE ON TERMINALS BEFORE MOUNTING THEM, BESURE TERMINALS ARE TIGHT !!! THE (NEGATIVE) CABLE OR GROUND IS VERY IMPORTANT ! A GOOD CONNECTION IS PARAMOUNT !!! INSPECT STARTER/SOLONOID CONNECTIONS, THEY MUST BE CLEAN, PROPERLY CONNECTED , TIGHT !!! TIGHT IS TIGHT, TOO TIGHT IS BROKE !!! MAKE SURE BATTERY IS IN GOOD,CLEAN CONDITION, FULLY CHARGED !!! YOU DID REPLACE THE STARTER WITH A NEW SOLONOID I HOPE ! ITS THIS ELECTRO-MAGNET THAT INGAGES THE STARTER INTO THE FLYWHEEL TO CRANK THE ENGINE . THEY WORK TOGETHER ! TAPPING ON THE STARTER TELLS ME, POSSIBLE LOOSE CONNECTION, EITHER INSIDE OR OUTSIDE SOLONOID . ALTERNATOR PROBLEM ? TAKE TO AUTOPARTS STORE, HAVE THEM CHECK BOTH THE BATTERY & ALTERNATOR . ITS FREE ! CHECK THE ALTERNATOR BELT FOR WEAR, WHETHER ITS TIGHT, LOOSE, ETC., A WORN OR LOOSE BELT WILL SLIP, NOT ALLOWING THE ALTERNATOR TO DO ITS JOB, CHARGING THE BATTERY !!! ONE MORE THING, ITS IMPORTANT TO KEEP THE ENGINE TUNED-UP, ESPECIALLY BOTH AIR & FUEL FILTERS, SPARK PLUGS & PLUG WIRES SHOULD BE REPLACED AS WELL, THEY DO WEAR OUT !!! DISTRIBUTOR CAP & ROTOR NEED ATTENTION ALSO, REPLACE THEM ! BACK TOO YOUR SRARTER/SOLONOID, SOMETIMES EVEN NEW ELECTRICAL PARTS GO BAD, IT HAPPENS ALOT, THEY COME FROM MEXICO, CHINA, ETC., NEED I SAY MORE ???
