Cars & Trucks Logo
Tex G Posted on Jan 26, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a case 580 backhoe, Construction King, with a shuttle shift transmission. It moves forward but will not move when I put it in reverse. What could be the problem?
Merle Evans
Level 3:
Master:
  • Cars & Trucks Master 275 Answers
  • Posted on Jan 26, 2017
Merle Evans
Level 3:
Master:
Answers
275
Questions
Helped
91423
Points
1242
Try taking your PTO unit out of gear.
Testimonial: "I just bought the tractor and am not sure where the PTO is. It is a backhoe with a front loader and a backhoe in back."
  • Tex G
    Tex G Jan 26, 2017
Volvo BL71 Backhoe Loader. It is jumping out of gears on reverse and in forward.
This is not a quick fix. Check fluid levels as the switching is hydraulic. You may need to consult a transmission expert if the synchro is failing.
The machine's Power-shuttle gearbox features four fully synchronized gears and electro-hydraulic switching between forward and reverse. For better balance, the transmission is mounted directly to the engine.
https://www.volvoce.com/-/media/volvoce/global/global-site/product-archive/documents/04-backhoe-excavator-loaders/04-volvo/v-bl71/v-bl71-bl71-plus-21c1002689-2010-04.pdf?v=HSEyPw
and
https://www.google.com/search?q=Volvo+BL71+Backhoe+Loader.+It+is+jumping+out+of+gears
What is the weight of a 1985 case super "e" backhoe?
Prior Models CASE Construction Equipment
I am guessing it is a 580 Super E. If so, go to the above link and search for 580 Super E. It will, although slowly, give you a click able link that will let you view specifications. There are a few options, so I will let you calculate the final weight.
Semper Fi,
Z
1helpful
2answers
On a case 580k 4x4 backhoe is 4th gear set up different then 1st 2nd 3rd tractor won't move in lower gears made no noises or grinding .
Hi Bill:
I'd check with my local Case dealer. We have several pieces of Case equipment with hydostatic drives.
If I remember correctly, high gear on a standard transmission is a 1:1 ratio in that the power is on a straight through shaft.
My suspicion would be that a shifter link ay have become dis-connected.
Here's a link that may assist.
https://www.google.ca/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=1987+case+backhoe+580k+4x4+transmission+diagram
Cheers
What can be wrong with my truck transmission?
I put my truck into drive or reverse n it will not move at all ...
www.cargurus.com > Questions > GMC > Sierra 1500
CarGurusJan 27, 2014 - I put my truck into drive or reverse n it will not move at all what is ... Try putting the transmission in low 1 or low 2, and see if it will move. ..... plus got a tune IP yesterday day . my car wantvgo forward or back but I can hear it go I ...
Truck Won't Move In Forward Or Reverse - Ford Explorer and Ranger ...
www.explorerforum.com/forums/showthread.php?t=237730
Feb 22, 2009 - 11 posts - ‎3 authors
Truck Won't Move In Forward Or Reverse Explorer & Ranger Transmissions, Transfer Cases, & Differentials.
Transmission won't go forward - Ford Explorer and Ranger Forums ...
www.explorerforum.com > ... > Elite Explorer 911!
Dec 10, 2007 - 5 posts - ‎3 authors
Transmission won't go forward Elite Explorer 911! ... I just got my Explorer off of the tow truck, so I have not had time to search anything out ... i had the same problem as above as well as no reverse. after a ton of research on ...
tranmission won't ingaged or move in drive - Ford F150 Forum ...
www.fordf150.net > ... > 1997 - 2003 Ford F-150
3answers
Why would a vehicle in reverse move forward
The question is a little vague but I think I know what your referring to. All modern automatic transmissions have torque converters. This is the device that connects the engine to the transmission. All vehicle manufacturers like the trans to be nice and smooth shifting. That's great but it does come with some minor drawbacks. If you are facing slightly down hill and you put your car in reverse but do not step on the gas slightly I can guarantee that you will indeed roll forward. You can eliminate that issue by holding your left foot on the brake while you shift into reverse. Then, as soon as you feel the trans engage, gently depress the gas pedal with your right foot and it will eliminate that forward roll problem.
I have a 2001 suburban that periodically locks up and wont move,but will if you shift gears from forward to reverse.any input
Is it a 4x4? Sounds like the transmission (or transfer case) is binding internally, or you brakes are locking up and shifting from forward to reverse frees them up.
6helpful
2answers
When i put my car in reverse it won't move but will drive forward perfect and is full of transmission fluid
Assuming this is an automatic transmission, odds are you have lost a band in your transmission, this will require a rebuild,  you may also notice it will fail to shift into high gear as well?
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
