Cars & Trucks Logo
Randy berg Posted on Dec 23, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
N14 cummins in a peterbilt getting large amounts of fuel in the oil. Replaced the pump heads and injectors and still doing it ?im told that is all it can be
SeabeeMechanic
Level 3:
  • Cars & Trucks Master 1,367 Answers
  • Posted on Dec 23, 2016
 SeabeeMechanic
Level 3:
Answers
1367
Questions
Helped
412624
Points
3754
Common problem on this engine and the current solution is to constantly change the oil to prevent overflow and then inter your DPF system if you have one.
One thing to try is have your computer re-programmed, but no guarantee it will solve your problem.
5 Related Answers
Anonymous
  • 77 Answers
  • Posted on Jan 02, 2009
SOURCE: How do I bleed the
CHECK YOUR GLOW PLUGS, THEY WORK LIKE A SPARK BY WARMING SYSTEM FOR FIRING.
Anonymous
  • 31 Answers
  • Posted on Feb 16, 2009
SOURCE: 85 s-10 2.5l no fuel from the injectors
electronic engine control unit calculates the mass of fuel to inject, not how wide it sprays. It's the type of solenoid that you use. Some have wider spray nzzles than others. An external Fuel pump helps the delivery of the fuel. Also since fuel injectors rely on mass air flows nowadays, you have to have proper mixture coming through. hows your Fuel pressure regulator?
The throttle position sensor reports to the computer the position of the throttle butterfly valve, which the ECM uses to calculate the load upon the engine-but inorder for this to run, you may need an external pump.
Sounds like nothing is being grounded back to the ECM to even give a reading. If your regulator is improper and you do not have a external pump (depending on your model), than check those. If not, Start from scratch.
If you ever lose your way, go back to the beginning_REWIRE!
Goodluck.
Anonymous
  • 4669 Answers
  • Posted on May 05, 2009
SOURCE: dodge cummins won't start, fuel reaching injector pump but no fuel coming out of injector pump.
You said you have fuel flowing from the inlet line of the injection pump? But not at the injector lines?
Anonymous
  • Posted on May 29, 2009
SOURCE: 1999 Dodge Ram 2500 Cummins 4x4, will not go above 25 mph
check the waste gate,its not returning to open position
Jonah Oneal
  • 14092 Answers
  • Posted on Oct 21, 2010
SOURCE: my 2001 dodge ram 24
CODE PO216 -FUEL INJECTION TIMING CONTROL CODE PO237 -MANIFOLD ABSOLUTE PRESSURE SENSOR A TC SYSTEM LOW INPUT. CODE PO382 - GLOW PLUGS CIRCUIT B MALFUNCTION.FAULTY WIRING,FAULTY GLOW PLUG RELAY.FAULTY GLOW PLUGS. CODE P1291 - NO TEMPERATURE RISE FROM INTAKE AIR HEATERS CODE P1693 - DID NOT SEE BUT LOOKING IN CODE BOOK P1691 P1694 PROBLEM IN THE FUEL INJECTION PUMP OUT OF CALIBRATION AND PROBLEM IN DIESEL PCM. DEALERSHIP HAS TO FIX.THEY HAVE TO HOOK UP DIESEL ENGINE TIMING EQUIPMENT TO TIME INJECTION PUMP TIMING CANT FIX AT HOME.
What injector number fit for 5.9 cummins common rail injectors?
no truck told
no year told
the answer is NO.
the injectors are matched 3 ways, (and more)
engine size and model.
injection controllers and tuned to the weight of the truck. and load.
start by naming where this engine sits.
none told.
no truck told or an end goal. at all.
just injector corundums.
2000 peterbilt. Why no power on hills?
diesel engines that has a power loss , (1) ck you fuel filters fuel pumps and make sure its getting all the fuel pressure , sometimes the lift pump goes and its runs only on the injector pump (but with no power ) second ck your air intake filters , ck your intake hoses , follow it all the way thru the turbo to the intake , look for cracks in flex connectors and missing clamps
also if your needing a pulling truck id look for a slightly larger engine for this one , as I do belive this engines only rated for about 312 hp and that's at about 22oo rpm !
this engine is common to find in medium sized earth moving equipment
What is the fuel pump pressure for a 91 dodge Cummins diesel?
what cummins diesel engine model is in the dodge
cummins make a large range of engines all of which have various pump pressures depending on the injector set up
ask your question again and concentrate on the engine details
2000 peterbuilt 379 cat where's the fuel pump located
Cummins N14 fuel problem Fix - YouTube
? 5:52
www.youtube.com/watch?v=YaFK-_ZbyBI
Jun 26, 2013 - Uploaded by Anderson E Rockefeller 98 Cummins N14 select plus for the past 6 months fuel pressure gauge keeped on ... I changed the injectors, fuel pump, turbo, and fuel lines. .... Read my other comment i left you also you need to replace the 90 degree check ..... N14 Cummins 2001 Peterbilt378 Hauling Scrap Metal Uphill - Duration: 4:15.
2answers
Engine misfires on one cylinder.n14 cummins.
If you know which cylinder then test / replace the injector. Check the wires and connections for that injector.
I have a 1999 dodge cummins 1500. While changing oil last weekend, i noticed i had a large amount of diesel fuel in the crank case. does this sound like a injector pump problem? it has 190000 miles on the...
How much is a "large amount"? And how long has it been since your last oil change? It is normal for a diesel engine to have fuel in the crankcase due to the high compression ratio. I believe if there is less than a liter (quart) after 4,000 miles then you have nothing to worry about. If it is more then I would suggest you have it inspected for leaking injectors.
2answers
We have a 3.2 DiD Misubishi Pajero and I think the injector pump is playing up. The car has just started surge and run rough and then starts to smoke like to much diesel is getting into the motor white...
You generally only get white fuel smoke from a diesel when one or more cylinders aren't firing. If it were injecting more fuel than can be burned into a cylinder that is firing you'd get black smoke. You can get gray smoke from a cylinder that is firing cold or late, but blue obnoxious smoke is more common with late injector pump timing. Dirty/failed injectors also generally make a rude blue smoke.
Run a can of Diesel Kleen through it. If you can't get it where you are call a local truck service and ask what they recommend for cleaning the pump.
Check and keep watch on the oil and coolant- white smoke from a warmed up diesel is usually coolant that is getting into the combustion chamber, typically from a failed head gasket or cracked head/block.
If you see any oil floating on the surface of the coolant, or if the oil starts to look milky, this motor must be serviced and the issue found or it won't last long.
lp
2answers
Have a 2001 Ford F-350 Super Duty 7.3 L Diesel... with a 30 HP Ford chip. Truck started having "hiccups", like it wanted to cut out and quit running. Took to have cam shaft censor replaced on a recall...
Have you tried removing the chip, reseting the pcm, then test drive without the chip, I do not work on diesels but I know I have had some 5.0s with compatibility problems with performance chips, for some reason on select cars the emissions system would through a fit and make the car run like crud with the chip in ran fine with it out although they accused it ran fine for a few months with the chip. if you havent you might try this just to see
37helpful
5answers
Dodge cummins won't start, fuel reaching injector pump but no fuel coming out of injector pump.
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
