SOURCE: DASHBOARD RADIATOR INDICATOR LIGHT COMES ON WHEN ENGINE IS COLD
you might need to get the water level sensor checked, it may be faulty
SOURCE: mitsubishi pajero io 1.8 GDI idle unstable
sounds like the cabbruter is losing pressure cheak tubes may be lose or damaged
SOURCE: water in the radiator reducing everyday in mitsubishi pajero IO
Good chance it's the plastic coupling linking the rear heater area and the front of the truck. It's a small Y-coupling. Breaks and leaks all the time. Easily exposed to everything, like snow and ice kicking up.
SOURCE: My Pajero GDI 6G74 sometimes just loses idling and cuts out
maybe the trotle ecu. convert it to manual
SOURCE: My car is Pajero Pinin GDI, when the car is cold,
to fix this you have to reset the idle by the following
if cold start car and take upto normal temp
switch ignition key to lock for 10 seconds
start engine and leave to idle for 10 min
turn off and immediatlly restart with air con on, fan on full and windows DOWN
for 10 minutes.
AGAIN turn off and immediatlly restart with air con on, fan on full and windows down for 10 minutes.
YOU IDLE IS NOW RESET
