When I indicate left it shows right on the back of my caravan and vice versa.The tow bar on the car is fine as we tow other things.Help please .Is there a wiring diagram Icould follow?
provided that the caravan is not over 3 tons and is fitted with electric brakes there will not be a problem
there is a load limit on the tow ball of around 150 kgs but if you use stabilizer bars ( which you should be using) , that makes it legal as the lift provided when you adjust the bars takes the load off the ball and makes the van more stable on the road
there will be a decal on one of the front door openings with the max towing load allowed
possible that the trailer plug is not wire correctly
it is also possible that the trailer has bulbs and the kia uses led units which will throw out the electronics
you may have to talk with an accredited auto electrician as there may need be an adaptor or blub change in the trailer electrics
How did you check it? Look at it? I think it's a sealed bearing. While driving, slowly sway the car left to right and back again. Does the noise become more prominent in either direction? When you put mor weight on a bad bearing they make more noise. Turning left puts more weight on the right side and vice versa.
Saves having to use a supplementary socket
01 Yellow Left Indicator 02 Blue Fog light 03 White Earth (35amp) 04 Green Right Indicator 05 Brown Right Side Light 06 Red Brake Lights 07 Black Left Side Light 08 Yellow Reversing Light 09 Green Permanent live 10 Blue Ignition live 11 Red Earth (35amp) 12 Black Coupled Trailers 13 White Earth (35 amp)
you need new signal switch assembly. unfortunately federal laws do not allow john q public to remove the steering wheels as the airbag has to be removed. Take it to the dealership or a reputable repair shop.
hi! first check the plug on the van,the socket on the car, then the little blue push connectors the fitters use,last but not least the lamp tabs on the lamp holder!
