Kodak Easyshare M753 Slim Digital Camera  Logo
Posted on Jul 19, 2009
When camera(m763) is turned on it switches itself off immeadiately
RBreaker
Level 1:
Problem Solver:
  • Contributor 19 Answers
  • Posted on Jul 19, 2009
RBreaker
Contributor
Level 1:
Problem Solver:
Answers
19
Questions
Helped
8623
Points
47
Are the batteries dead
High camera temperature camera will be turned off
We see this happen at my photo store when there is a battery issue. Something like that will more then likely need to be sent off for repair.
Dropped the camera now the lens is stuck
You'll need to take your camera in to a repair shop, where they will likely charge you parts plus labor. This may exceed the value of the camera itself, so you may just be stuck with purchasing a new digital camera.
My cam doesnt switch on
i there please follow the steps and let me know the result.
1. Ensure batteries are fully charged.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine .
Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a
back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec ..
in not done the press both Menu & self time key for 2 - 4 sec.
Camera wont turn on-batteries are OK
Here are the steps for M763 no power problems: 1. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Turn the camera on. 2. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a no power repair with KODAK or a new cable.
My kodak M763 lense is sutck and the camera wont turn on
Here are the steps: 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable.
1helpful
My Kodak M763 camera won't turn on, ( It is not the battery because I bought a new one)When I press the on button, It looks like is going to start, but it turns off again.
If the camera has recently been dropped you may have lens damage which is preventing it from powering up. If it hasn't been dropped, your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
If this response helps, please post a rating for me. A rating of "Very Helpful" would be appreciated . .
I have a Kodak M763. The camara don't want to turn on. Don't work
If you have recently dropped the camera you may have damaged the lens tube (housing). This damage will prevent the lens from moving properly and will cause the camera to shut itself off after a few seconds. If the lens is damaged the camera will require professional repair. If the lens is not damaged, the problem may be battery related. Make sure that you have the correct battery type installed, and that the batteries are fresh/fully charged. If the problem persists, you may have corrosion on the battery contacts inside that camera that is preventing full battery power from flowing to the camera. Remove the batteries and wipe the inside camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sand paper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and reinstall them in the camera. This cleaning solves the problem about 90% of the time, and I hope it works for you.
1helpful
Lens will not retract. camrea frozen my camera will flicker on and off and the lens will not retract. it is a kodak M763, first time this has happened.
When the lens will not retract and camera is not functional (no picture on display, and does not shoot) , and you already tried replacing batteries with a new fresh set (ensure please) , and then restarting camera with no memory card inside, then camera is faulty.
Try an easy fix by pushing gently the lens (do not force them, just help them) while you turn off camera at same time. Try also switching the mode selector.
If still no luck , then the camera must be disassembled to fix the problem.
Possible reasons are :
  • Faulty lens mechanism or jammed lens (camera usually turns off by itself in this case)
  • Main board faulty.
  • Ribbon cable to main board broken or connector defective.
  • If there is no power at all it is the connector from batteries to main board, this is also a ribbon cable.
If the camera is less than one year old will be replaced by manufacturer.
If your warranty is expired you can get an estimate for repair from manufacturer, or from a third party like Advance Camera here :Advance Camera Repair you can book the repair online.
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
