SOURCE: gas is leaking from the leaf blower.
Unless the tank has been cracked, it has to be one of the following: Broken lines, split primer bulb, unsealed fuel cap, bowl gasket of carb. I would start with the lines and bulb since they are the ones usually at fault..Good luck...Lee
SOURCE: I have the Echo PB 265L leaf blower.
I had the exact same problem with gas soaking my back and found out the yellow fuel discharge tube that comes out of the carberator was not inserted into the rubber gasket on top the fuel tank. The gasket has 3 holes in it for 3 tubes and the yellow tube fits into one of the holes. Hope this helps. It is a bit difficult to get the tube in the hole, but at least if you know what you are looking for you can get it to work
