When I put off engine it was dripping under neath car
If there is antifreeze in the water, then it comes from somewhere on the engine. An inspection of hoses , radiator and freeze plugs is in order. If there isn't antifreeze in the water, then it is most likely condensate coming from the AC case. This is normal if the humidity is high and you use the AC a lot.
SOURCE: Water dripping from underneath
That hose is the drain hose for the a/c. When condensation forms from running the a/c it drains out through the black hose you are refering too.If it doesn't drain out it will eventually overflow inside the car and get your carpet wet.
SOURCE: engine vibration in drive or reverse
Wow..thats not good..first have motor mounts checked, maybe the tranny mount or possibly if ur car has it is the driveshaft bearings...good luck on the oil leak...maybe tranny fluid..make sure if ur losing fluid that ur checking them incl. the tranny fluid...u might find ur leak first of all by rechecking the oil cap where it is supposed to be ...same with all fluid caps.
SOURCE: leak under car
if it's water, and not gas it's not your fuel pump. if it's water and not a sweet smelling green or red liquid it's not your cooling system. it's probally condensation from your ac, have you been using your ac alot? if so no worries. or a bad window or door seal and it's letting in water onto your floor. and yous aid under the door, so it's on the ground or on the floor of the vechile? if on the ground, more then likely it's just your weep drain from your ac system.
SOURCE: Water dripping under engine - Is it the water pump?
if the car has a/c this is normal as this is how the a/c system gets rid off the humidity(WATER)that it takes out of the air in the car. hope this helps, if not get back to me. please rate my fix as i strive to be the best Thanks Ray
SOURCE: water leaking in glove box?
There are three possible fluid can leak though the glove box.
Leaves and dirty block the drainage pathway..
Rain water/car wash water will seek the lowest spot.
AC condenser water drainage pathway may be block.
Windshield washer hose come off and window washer fluid somehow find it was to the interior.
Try to identify the smell of the liquid. It may just be Wet ones wipes.
Good luck
