SOURCE: 1990's Emerson Quiet Kool window air conditioner
Hi, It opens a flap that allows fresh outside air to come in. The opening it screen covered on most units so no insects get in. To get the most cooling it is best to leave it closed. If you want fresher air, open it. Please rate my suggestion if it has helped. Thank you and, Have a good day. kstfas
SOURCE: emerson quiet kool wall air conditioner. Should
No - opening the vent will allow unconditioned outside air into the space and add to the humidity load.
Think of it like your car's A/C - when you put the controls to "Max A/C" the system recycles just the air inside the car and doesn't use any outside air. When the control is set to normal A/C, some outside (fresh) air is brought in.
The same thing is true for a window A/C unit. Keeping the vent closed will help the unit de-humidify and cool the air more quickly.
SOURCE: emerson quiet cool air conditioner
Make sure you do not have it on fan and have it set on cool/cold. Otherwise you may need to have the it recharged by a h-vac professional. Also you can try clean the filters and the compresser/condenser (the part that is out side. Sometimes Dirt can keep your unit from working to it full potential.
SOURCE: what is the setting for the push-pull lever on the
If you want to pull fresh air into the room and not use the cooling part of the unit. pull the lever out. If you don't want to introduce fresh air into the room during the cooling cycle, push the lever in.
Thanks for choosing FixYa.
