Cars & Trucks Logo
Thomas Weber Posted on May 13, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2005 GMC Yukon Denali drivers seat turns on and off by itself
The drivers seat heater turns on and off by itself
Marvin
Level 3:
Top Expert:
  • GMC Master 85,242 Answers
  • Posted on May 14, 2016
Marvin
GMC Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29060247
Points
266281
The common cause is the control is defective.
Denali seat heater on driver's side come on upon start up. After shutting down it immediately restarts. Cannot seem to keep it off.
Bad switch or control module. You could try swapping left and right switches if the connector fits, to help determine the problem. If the other switch stays off, get a new switch. If it acts the same, get a control module.
2003 Yukon Denali.driver car seat heater don't wonk
The seat heater grid is likely shorted.
Front seat heaters not working in a 2002 yukon denali
Make sure to check out the power fuse with the multimeter and check the switch. Most probably its due to burning of seat heater wiring.
Our Driver Seat Heaters and passenger seat will turn on for 2 sec
When this was happening on my Envoy it ended up being the seat heaters control module that was going out. About $600 a seat on mine. Just wish my repair center found that out before they replaced the seat heaters twice.
4helpful
Heated Seats, Yukon Denali
You will need to replace the switch module, it is the only thing that can cause this to happen
02 GMC Denali front heated seats won't work
The controller could be bad but I would probe the related wiring first. From your symptoms it sounds like something can not handle the electrical load. You turn the F/R seat heater on but then you turn on the F/L and the whole system fails. It does sound like the source of the problem will be under the drivers seat. Testing needs to be performed to confirm and identify the source. Both seats share the same fuse and ground. This circuit may have a damaged wire or connector somewhere. Inspect and test as much as you can. Also look underneath the seats for anything. Customers are not aware that personal belongings and trash get pushed underneath the seats and will damage wiring. Also excessively moving the seat forward and back will weaken the harness over time. Please write back and let me know what you need. If it is more diagnostic information or suggestions just let me know. Good Luck
test to see if you have any power going through all the connectors for the seat heater, there may be a spot where there is a connector that has gone bad, or potentially it could be the whole element that is bad
Top GMC Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a GMC Expert? Answer questions, earn points and help others
