Cars & Trucks Logo
Poncho da Dog Posted on May 04, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Craftsman lt2000 engine won't run at full speed; idle ok, 33% gas=33% RPM, 50% gas=50% RPM, & 100% gas=50% RPM. So far I have only blown clear the air filter. Will atmpt tbl shooting this weekend.
Marvin
Level 3:
Top Expert:
  • Cars & Trucks Master 85,242 Answers
  • Posted on May 04, 2016
Marvin
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29061405
Points
266281
5 Related Answers
Anonymous
  • Posted on Feb 28, 2009
SOURCE: engine stalls after cold start-up & release from high speed idle
I had a similar problem.  I found the filter cartridge below the pcv valve had carboned up, and after the crank case pressurized, oil was forced out the pcv supply line to the throttle body.  The idle air control valve solenoid got oil in it and caused my problem, but only when it was cold.  The pcv cartridge is accessed by removing the pcv valve and the rubber fitting that the pcv valve mounts in.  It can then be fished out with a pick set, and it is a pain because you can't see it, but you can get you hand back there.  I hope this helps you.
Anonymous
  • 453 Answers
  • Posted on Apr 28, 2009
SOURCE: throttle/Idle/running problem - wants to run too fast, or stall out
RPM's up and down check EGR valve and sensor. EGR valve and sensor control idle. That's why your getting the surging on rpm's and this could be giving out the other codes. If mass flow was bad car will not start and the same for the map sensor. O2 sensor measures gas and air for right mixer. TPS controls 0-60 speed as in throttle respons.
FtheT
  • 22 Answers
  • Posted on Jun 18, 2009
SOURCE: 2001 Forester, Rough idle and engine loping driving at low rpm
I had a similar problem on my 2002 Impreza RS 2.5 (same engine and engine control system). In my case it was the O2 sensor on the intake manifold. This happened at 34,xxx mi. so it was covered by the warranty. Replacing the part is very easy. (two bolts and a wiring harness). Obviously I would start simple and cheap and work your way to expensive and difficult.
From my understanding its all caused from the engine missfiring. If its been a while or never, I'd change the spark plugs first. (stick with the Subaru Parts plugs, I went after market and the dealer claimed the plugs were not the correct "temperature" and had to pay for the new plugs and install although they did it without my permition. Thats a whole nother story).
Could also be the manifold pressure sensor.
Either 02 or manifold pressure sensor may cause intermitent check engine light.
Where I live Brookline,MA , Autozone will run a free diagnostic on your car by hooking up to your ECU and will give you the trouble codes and possible remidies. Of course there are no guarentee's but it will point you in the right direction.
Good Luck
Molson02536
Harvey N Tawatao
  • 3854 Answers
  • Posted on Jul 04, 2009
SOURCE: How to I set idle speed?
Before performing any on-vehicle adjustments to fuel or ignition systems, ensure engine mechanical condition is okay. CAUTION: When battery is disconnected, vehicle computer and memory systems may lose memory data. Drive ability problems may exist until computer systems have completed a relearn cycle.
IDLE SPEED & MIXTURE
NOTE: Idle mixture is controlled by Powertrain Control Module (PCM). Adjustment is not possible. After replacement of Idle Air Control (IAC) valve, system must be cycled as identified for PCM to properly control idle speed. If idle speed is not okay after cycling system, problem is usually caused by a dirty throttle plate or vacuum leaks. Ensure all vacuum components are functioning properly.
IDLE SPEED (4-CYLINDER)
Turn ignition on with engine off for 10 seconds. Turn ignition off for 10 seconds. Start engine and idle for 30 seconds. Slowly vary engine speed between idle and 3500 RPM 5 times. Return engine to idle. PCM will now properly control idle speed. 2.2L (Cavalier & Sunfire) & 2.4L (Alero, Cavalier, Grand Am & Sunfire)  Good luck and hope this helps. If it still has the high idle problem, your going to have to buy a can  if not two cans ot THROTTLE BODY CLEANER NOT CARBURATOR CLEANER. Just follow the instruction on the can and try to get the Idle Air Control Valve cleaned also which is on the sdie of the throttle body so go to town when cleaning the throttle body and then do the Idle speed relearn again. The other thing to is since your doing house cleaning, buy a MAF sensor cleaner and spray down your MAF sensor and IAT sensor also, this will help with your fuell consumption.
Good luck and keep me posted, be glad to help.
steve noel
  • 750 Answers
  • Posted on Jul 09, 2009
SOURCE: Rough idle engine ticking
check for a lose spark plug lead or cracked elecrod insulation on spark plug
1helpful
2answers
2answers
When air conditioner clutch engages it pulls down all vehicle voltage and belt and clutch start to slip
belt worn, loose or idler pulley weak --compressor clutch binding,moisture in system ,compressor internal damage
Truck dies when idling
HI
first I would like to tell you, do this procedure only if the 5th digit of your VIN is C or K.
Description
The engine control module (ECM) learns the idle position of the throttle plate to ensure the correct idle. Anytime the throttle body is cleaned or replaced, the ECM must learn the new throttle position. The idle may be unstable or a DTC may set if the throttle position is not learned.
Conditions for Running the Throttle Learn Procedure
• DTCs P0101, P0102, P0103, P0107, P0108, P0111, P0112, P0113, P0506, and P0507 are not set.
• The engine speed is between 450-4,000 RPM.
• The manifold absolute pressure (MAP) is greater than 5 kPa.
• The mass air flow (MAF) is greater than 2 g/s.
• The ignition 1 voltage is greater than 10 volts.
Throttle Learn
Important: Do NOT perform this procedure if DTCs are set. Refer to Diagnostic Trouble Code
(DTC) List - Vehicle.
1. Start and idle the engine in PARK for 3 minutes.
2. With a scan tool, monitor desired and actual RPM.
3. The ECM will start to learn the new idle cells and Desired RPM should start to decrease.
4. Ignition OFF for 60 seconds.
5. Start and idle the engine in PARK for 3 minutes.
6. After the 3 minute run time the engine should be idling normal.
Important: During the drive cycle the check engine light may come on with idle speed DTCs. If idle speed codes are set, clear codes so the ECM can continue to learn.
* If the engine idle speed has not been learned the vehicle will need to be driven at
speeds above 70 km/h (44 mph) with several decelerations and extended idles.
7. After the drive cycle, the engine should be idling normally.
* If the engine idle speed has not been learned, turn OFF the ignition for 60 seconds
and repeat step 6.
8. Once the engine speed has returned to normal, clear DTCs.
Good Luck
1helpful
Increase then decrease idle when engine is cold especially
cold engine idle surge. (problem)
RPM range of surge not stated
300-700 or 800 to 1500? (range is critical to diagnosis)
bad fuel
running summer fuel in winter (running old fuel?)
needs a tune up bad, see the list in the operator guide.
idle speed controller,sticking or EGR valve same. (clean them)
location not stated, so cant guess about local air temps.?
no other symptoms, lack of engine power? etc?
was it ok last week, or better, when was the last time it was OK?
1week, 1year?
surge , causes, on a tuned engine might be:
1: too lean. so lean the ISC can not control idle. rpm low, stalling
2: too rich, flooding, stalling, spark plugs foul (look at them)
3: weak compression in 1 or more cylinders.
4: bad spark.
5: air leaks, in the plenum causing , ISC to lose control.
why high RPM?
especially?
well that means it fails hot too.
and there is a simple tests. for hot surge.
is engine fully hot? 180F and holds solid there?
say rpm is about 800
and you turn on head lights, heater fan and (not AC) and defrost.
the RPM must hold or the ISC is failing.
ISC -= idle speed controls. (all EFI has this function)
1helpful
How do u get the 1990 DODGE ramcharger to stay idleing
Engine stall or RPM fluctuates at idle.
This problem is commonly caused by a dirty automatic idle speed control valve and throttle valve. Buy a can of throttle valve cleaner (do not use carburetor spray cleaner!) from NAPA or Carquest (made by CRC chemicals) and spray it into the air intake while the engine is running, use up about 1/2 the can, engine will try to stall hold the speed up, shut it down and let it soak for 30 minutes, restart and blow out the remaining fluid, shut it down and disconnect the negative battery cable for 5 Min's to reset the base idle control
98 Expedition..5.4L 4WD..coded bank 1 bank 2....O2 sensors..LEAN....replaced both..no change..still same codes..now it won't stay running. Tried to code again..won't run long enough to get a c
Really sounds like a vacuum leak. Lean code could still be accurate. Screaming idle usually means air is getting into engine. Ruptured EGR diaphragm would vent air. Brake booster could vent air. A lot of air will show lean mix.
You may have to use different methods to test vacuum. Some use vacuum gauge to test egr and lines which dead end into solenoids. Other tests use water spray or propane gas to draw in and change rpm. You are at a disadvantage if engine does not run.
Crankshaft sensor helps set fuel volume for given rpm. Might not be counting all the rpm's, but would not account for fast idle.
2helpful
2answers
Throttle/Idle/running problem - wants to run too fast, or stall out
2000 v6 5 spd nissan xterra idles high when in gear and rolling .
From the service manual:
Idle Speed/Ignition Timing/Idle Mixture Ratio Adjustment
NGEC0549
PREPARATION
NGEC0549S01
1) Make sure that the following parts are in good order.
I Battery
I Ignition system
I Engine oil and coolant levels
I Fuses
I ECM harness connector
I Vacuum hoses
I Air intake system
(Oil filler cap, oil level gauge, etc.)
I Fuel pressure
I Engine compression
I EGR valve operation (If so equipped)
I Throttle valve
I Evaporative emission system
2) On air conditioner equipped models, checks should be carried out while the air conditioner is OFF.
3) On automatic transmission equipped models, when checking idle rpm, ignition timing and mixture ratio,
checks should be carried out while shift lever is in “N” position.
4) When measuring “CO” percentage, insert probe more than 40 cm (15.7 in) into tail pipe.
5) Turn off headlamps, heater blower, rear defogger.
6) Keep front wheels pointed straight ahead.
7) Make the check after the cooling fan has stopped.
SEF976U
3. Open engine hood and run engine at about 2,000 rpm for about 2 minutes under no-load.
SEF977U
4. Perform diagnostic test mode II (Self-diagnostic results). Refer to EC-644.
SEF217U
OK or NG
OK ' GO TO 2.
NG ' 1. Repair or replace components as necessary.
2. GO TO 2.
BASIC SERVICE PROCEDURE VG33E
Idle Speed/Ignition Timing/Idle Mixture Ratio Adjustment (Cont’d)
EC-616
2 CHECK IGNITION TIMING
1. Run engine at about 2,000 rpm for about 2 minutes under no-load.
2. Rev engine (2,000 to 3,000 rpm) two or three times under no-load, then run engine at idle speed.
SEF978U
3. Turn off engine and disconnect throttle position sensor harness connector.
SEF975R
4. Start and rev engine (2,000 - 3,000 rpm) two or three times under no-load, then run at idle speed.
5. Check ignition timing with a timing light.
SEF371S
15°±2° BTDC (in “P” or “N” position)
OK or NG
OK ' GO TO 4.
NG ' GO TO 3.
GI
MA
EM
LC
FE
CL
MT
AT
TF
PD
AX
SU
BR
ST
RS
BT
HA
SC
EL
IDX
EC-617
3 ADJUST IGNITION TIMING
1. Adjust ignition timing by turning distributor after loosening securing bolts.
2. Turn off engine and connect throttle position sensor harness connector to throttle position sensor.
SEF972R
' GO TO 2.
4 CHECK BASE IDLE SPEED
With CONSULT-II
1. Read idle speed in “DATA MONITOR” mode with CONSULT-II.
PEF356V
700±50 rpm (in “P” or “N” position)
Without CONSULT-II
1. Check idle speed.
OK or NG
OK ' GO TO 6.
NG ' GO TO 5.
13helpful
Car idles low, stalls after start
Common issue at the shop (i'm a ford technician), here is what I do to correct it.
Here is the most common cause of surges and stalls at stops and low erratic idle speed and rough idle, it is the idle speed control air-bypass valve and throttle valve (IAC for short), they get full of gunk over the miles and cause idle issues (stalls, low idle) like yours, Get a can of intake cleaner from any local parts store, not carb spray, intake cleaner, it is made by a company called CRC, remove the air intake hose to the engine, hold the idle high so the engine won't stall, then spray the can of cleaner into the intake while keeping the engine running, use at least 1/2 the can, shut down the engine and disconnect the battery for 5 minutes, then restart and complete a number of mixed driving cycles, town, freeway, stop and go etc., after a few days the problem will go away as the system will relearn to the clean intake.
Xterra repair
Since this is an intermittent problem, first try to determine if the problem arises due to one of these many intermittent problems:
* Vehicle vibration
* Heat sensitive
* Freezing
* Water intrusion
* Electrical load
* Cold or hot start up
If you can't isolate the cause of the intermittent problem, you can try adjusting the Idle Speed/Ignition Timing/Idle Mixture Ratio:
PREPARATION
* Battery
* Ignition system
* Engine oil and coolant levels
* Fuses
* ECM harness connector
* Vacuum hoses
* Air intake system
* (Oil filler cap, oil level gauge, etc.)
* Fuel pressure
* Engine compression
* EGR valve operation (If so equipped)
* Throttle valve
* Evaporative emission system
INSPECTION PROCEDURE
1 INSPECTION START
1. Visually check the following:
I Air cleaner clogging
I Hoses and ducts for leaks
I Electrical connectors
I Gasket
I Throttle valve and throttle position sensor operation
2. Start engine and warm it up until engine coolant temperature indicator points to the middle of gauge.
Ensure engine stays below 1,000 rpm.
OK or NG
OK ' GO TO 2.
2. GO TO 2.
OK or NG
OK ' GO TO 4.
NG ' GO TO 3.
' GO TO 2.
OK or NG
OK ' GO TO 6.
NG ' GO TO 5.
5 ADJUST BASE IDLE SPEED
1. Rev engine (2,000 to 3,000 rpm) 2 or 3 times under no-load then run engine at idle speed.
2. Adjust idle speed by turning idle speed adjusting screw.
' GO TO 6.
6 CHECK TARGET IDLE SPEED
1. Turn off engine and connect throttle position sensor harness connector.
2. Start and rev engine (2,000 to 3,000 rpm) 2 or 3 times under no-load then run at idle speed.
3. Check idle speed.
750±50 rpm (in “P” or “N” position)
OK or NG
OK ' GO TO 9.
NG ' GO TO 7.
7 DETECT MALFUNCTIONING PART
Check the following.
1. Check IACV-AAC valve and replace if necessary.
2. Check IACV-AAC valve harness and repair if necessary.
3. Check ECM function by substituting another known good ECM.
(ECM may be the cause of a problem, but this is rarely the case.)
' GO TO 9.
9 CHECK FRONT HEATED OXYGEN SENSOR LH SIGNAL
2. Set “Left bank front heated oxygen sensor monitor” in the Diagnostic Test Mode II.
3. Make sure that MIL goes on more than 5 times during 10 seconds at 2,000 rpm.
OK or NG
OK ' GO TO 12.
NG (MIL does not blink.) ' GO TO 17.
NG (MIL blinks less than 5 times.)
' 1. Replace front heated oxygen sensor LH.
2. GO TO 10.
10 CHECK FRONT HEATED OXYGEN SENSOR LH SIGNAL
1. Warm engine to normal operating temperature.
2. Run engine at approx. 2000 rpm for approx. 2 minutes under no-load.
3. Set “Left bank front heated oxygen sensor monitor” in the Diagnostic Test Mode II.
4. Make sure that MIL goes on more than 5 times during 10 seconds at 2,000 rpm.
OK or NG
OK ' GO TO 13.
NG ' GO TO 11.
11 DETECT MALFUNCTIONING PART
1. Check fuel pressure regulator.
2. Check mass air flow sensor and its circuit.
3. Check injector and its circuit.
Clean or replace if necessary.
4. Check engine coolant temperature sensor and its circuit.
5. Check ECM function by substituting another known good ECM.
' GO TO 2.
13 CHECK FRONT HEATED OXYGEN SENSOR RH SIGNAL
1. Set “Right bank front heated oxygen sensor monitor” in the Diagnostic Test Mode II.
2. Make sure that MIL goes on more than 5 times during 10 seconds at 2,000 rpm.
OK or NG
OK ' INSPECTION END
NG (MIL does not blink.) ' GO TO 16.
' 1. Replace front heated oxygen sensor RH.
2. GO TO 14.
14 CHECK FRONT HEATED OXYGEN SENSOR RH SIGNAL
3. Set “Right bank front heated oxygen sensor monitor” in the Diagnostic Test Mode II.
OK or NG
OK ' INSPECTION END
NG ' GO TO 15.
15 DETECT MALFUNCTIONING PART
3. Check injector and its circuit. Clean or replace if necessary.
' GO TO 2.
16 CHECK FRONT HEATED OXYGEN SENSOR RH HARNESS
1. Turn off engine and disconnect battery ground cable.
2. Disconnect ECM harness connector.
3. Disconnect front heated oxygen sensor RH harness connector.
4. Check harness continuity between ECM terminal 50 and front heated oxygen sensor RH harness connector.
Continuity should exist.
OK or NG
OK ' 1. Connect ECM harness connector.
2. GO TO 18.
NG ' 1. Repair or replace harness.
2. GO TO 9.
17 CHECK FRONT HEATED OXYGEN SENSOR LH HARNESS
3. Disconnect front heated oxygen sensor LH harness connector.
4. Check harness continuity between ECM terminal 51 and front heated oxygen sensor LH harness connector.
OK or NG
2. GO TO 18.
2. GO TO 9.
18 PREPARATION FOR “CO” % CHECK
1. Disconnect engine coolant temperature sensor harness connector.
2. Connect a resistor (4.4 kW) between terminals of engine coolant temperature sensor harness connector.
' GO TO 19.
19 CHECK “CO” %
1. Start engine and warm it up until engine coolant temperature indicator points to the middle of gauge.
3. Check “CO” %.
Idle CO: 1.5 - 9%
After checking CO%,
a. Disconnect the resistor from terminals of engine coolant temperature sensor.
b. Connect engine coolant temperature sensor harness connector to engine coolant temperature sensor.
OK or NG
OK ' 1. Replace front heated oxygen sensor LH.
2. GO TO 10.
NG ' GO TO 20.
20 DETECT MALFUNCTIONING PART
1. Connect front heated oxygen sensor harness connectors to front heated oxygen sensors.
2. Check fuel pressure regulator.
3. Check mass air flow sensor and its circuit.
4. Check injector and its circuit.
5. Check engine coolant temperature sensor and its circuit.
6. Check ECM function by substituting another known good ECM.
' GO TO 2.
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
